  • Replies 87
Posted Images
  • 7 months later...
  • 3 years later...
Yeah, Well, not much has been happening round here but were trying to get things going. Seems that just as many people out of NT post here as those from NT. Which can be very helpful. Very few from Alice which is a bit disapointing! I am gunna keep coming back!!
I guess most ppl post in Boost as the are bugger all skylines in NT, One thing that is happening tho is we have started our own official drift club, it is tied in with NAMSC so that we use the track (hidden valley) the same day they do lap sprints. It's called TEDA (top end drift association)
Awesome..we are trying to get one going here too..slowly... :( I really hope it works out, already have a couple of potential sponsors if everything gets aproved.
Hi mark , I am also a member of SAUQLD as I used to and will be again living in QLD, hay Azriel me and the other smurfs up in Darwin would love for you guys to come up for a drift day one time , does not have to the next one but , the next one is the 30th sep 07 , applications have to be in on the 14th of sept , check www.namsc.org.au I think , just google namsc and you will find it or the NT drift fourm on Boost.
Hi jaqule, Thanks for the invite..Myself and the guys here would love to get up there for a drift with you,,,,but easier said than done. This ones a bit soon but I'll try for a later one..See how it goes!! If your ever down here look me up..
Hey markimak, and the rest of Qld.!! :)
hiya just thought ill spread the love
come to brisbane.. watch the DA when its on next.. and i just put my cusco 2way in :D
head east and come to QR
Have they fixed the ripples on the track at turn 1 & 3 yet ? Have to say after drifting on both tracks , hidden valley is so much better , shows what a real track should be like!
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
