im about to start a high hp 30 motor. i know most of the things require but have i missed any out and what weakness are there at 700-800hp.. i dont want to do anythin thats not realy vital but any suggestiong would be great
30e block..30e crank will need big end grinding..
carrillo rods,, wisco pistions (good coice?)
std gtr oil pump ?ok?
knife endged and balanced crank (inc flywheel & power enterprice pully)
and thats pretty much what def will be getting done..
will be for dyno runs only at high power.. and maybe drag at lower power levels,
things im not sure about are (to save on build costs)
o ring block? or any extra block strengthing.
trust oilers on main bearing trust?
head studs? main studs? vs std gtr ones.
any heat treating/coatings?
26 mains and grinding channel in 30e block?
oil squirter fitting?
or any think else i have missed?
i dont want to do anythin thats not realy vital but any suggestiong would be great. ps that 30 post is far to big and its full of crap most and cant sniff out important info..
std gtr oil pump ?ok?No, at least an N! pump with crank collar
knife endged and balanced crank (inc flywheel & power enterprice pully) I also got the crank cryogenically treated
o ring block? or any extra block strengthing.Not needed
trust oilers on main bearing trust????
head studs? main studs? vs std gtr ones. Yep, ARP do these, retap block to take Rb26 head studs
any heat treating/coatings?Recommend getting pistons coated
26 mains and grinding channel in 30e block?????
oil squirter fitting?Good idea, but aparently very difficult to do(about to find out)
its because the info is so bitsy its spread out on the sticky and most people arent actually answering the questions just talkin shit.. kinda like now.. if you canno help be please dont bother posting... anf you rite.. i dont have 3 weeks either.. i would rip my hair out before then im already since of the smack talk on there..
For a 'reliable' 700-800hp, everything will need to be modified or changed, particularly the valve train and head porting (you are using the SOHC 12V head, yeah?)
what is everthink..?? what have i missed mentioning
im using nothing less than a rb26 head jun intake 85mm throttle medium porting and mild apexi cams & pullies.. im more consorned about the strength mods not the head mods.. i know my head and turbo setup can make the power.. i just want it to hold down below..
can anyone helpme on some of these things..
whats required and whats not or any others i have missed
Edited by GDZ1LA
i just built mine to handle 700rwhp tops
basically need everything done yes.... pm me for more info, i could try send ya a list of my mods, theres just way too many here to list
get 1/2 inch head studs, block studs, if u can get the turbo, mani and dump coated then do that, i use a trust oil pump, was using gtr oil pump before but definatley dont want to risk it.....
ben...
GDZ1LA - Please read the RB30 sticky and also search.
There is more than enough info on what your asking about this forum.
People cant be expected to answer/repeat themselves time and time again.
If you do truly want to build a 700-800hp motor, then taking the time to read a detailed thread should be the least of your issues.
Rushing into a build is what will be the sad end to it.
Thanks
    • Sorry I think that must be another language thing, globe = light bulb
    • Man, you guys are like an all knowing encyclopedia.. how do you guys know how to fix everything?? but thanks. i will try to trace this wiring today. What is this globe thing you are referring too? Globe Power Supply? Are you referring to the light bulb?
    • Vinyl paint always ends up coming off interior trim and looking like arse. For the a pillar trims.....just try cleaning them with fabric shampoo? Maybe ditto for the headliner.
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
