only THE sexiest wagon, even better than a stagea
there is also a US company that specializes in teh suspension and power of these bad boys
its beggggging for a top grill intercoler and bottom radiator
https://www.sau.com.au/forums/topic/166418-forester-sti/#findComment-3082064
the white one looks schmick but not a fan of the blue/silver ones face, must be a different year model i am guessing?
and they all still have thae usual subaru shoe box look, gimme the stag for sleek lines any day of the year.
just my 2cents
https://www.sau.com.au/forums/topic/166418-forester-sti/#findComment-3082103
horribly.
IMO
ive driven a WTX STI wagon, forester STI wagon, Lancer Evo Estate (that is frickin sexy)
and i think the stagea is a pig compared to them, but 3,000 VS 18-20,000
STagea has my vote
https://www.sau.com.au/forums/topic/166418-forester-sti/#findComment-3082135
Evo Estate????
picsorban!!!!!!!!!!!!!!!!!!!
Just out of curiosity, have you driven the mitsu Legnum wagon? I have been looking at them closely but they are pretty much an unknown entity over here.
like this..
http://www.j-spec.com.au/list/index.php?ID=9815
(yes, I am a complete and utter wagon tragic)
https://www.sau.com.au/forums/topic/166418-forester-sti/#findComment-3082295
Evo Estate????
like this..
i am RIGHT there with you
i have a horrid wagon fetish.
THe legnums from what i hear are great, but imagine workign on a Z32 or 3000GT....the engine bay is a horrrible area. for that fact alone i woudlnt get it, and i am a mitsu fanatic
evo estate
https://www.sau.com.au/forums/topic/166418-forester-sti/#findComment-3082407
Evo 9 Wagon is the shit. It's essentially the same as an Evo 9, but no Active Yaw Control.. Apparently the extra 80kg's over the rear wheels from the body helps the rear end to grip.
Also helps the rear end to slide out more.. and without AYC, it can do so for a while ;)
https://www.sau.com.au/forums/topic/166418-forester-sti/#findComment-3082533
yeah the STi forester is amazing.. i would have considered getting a GT or XT if they didnt have glass diff's ;)
Thats why they have a warning light for rear diff temperature. Also try SIX sets of rear wheel bearings.
Forester, the WORST car I have ever bought.
Parts are friggin expensive. Try $680 for a coil pak, $40+ for a plug lead. Localdealer wanted $1100 to fit new timing belt.
Incidently, Mrs66 drove it most of the time, only went offroad once.
https://www.sau.com.au/forums/topic/166418-forester-sti/#findComment-3082689
my best mates brother just got a brand spanking new XT forester, when the clock hit around the 17k mark the rear diff blew. replaced the rear diff and center bearings. Iv got about 3 or 4 other mates who have experienced driveline problems in both WRX and forester. all Subaru’s technology is under engineered and too primitive compared to what all the other companies have been doing.. i mean the EJ has been in production for that long its ridiculous. also, the foresters only have a R160 diff, they could fit in a handbag!
Apparently Toyota is set to buy out Subaru in the very near future.. it will be interesting to see what comes from this
Edited by Brycey
https://www.sau.com.au/forums/topic/166418-forester-sti/#findComment-3082802
the forester sti is pretty kickass. Apparently faster than a wrx sti in certain forms in a straight line. Unfortunately the Stagea is the slowest wagon, even legnums are faster. Legnums are more common than stags over here, mechanically the stagea is stronger by miles.
https://www.sau.com.au/forums/topic/166418-forester-sti/#findComment-3082921
Nissan's have always been very conservative in stock form.
Even the GT-R's, although relatively fast and responsive, are still far from running at their peak performance.
Just a thought, how would stagea's compare to the above list when modified to reach their full potential on stock internals (eg. you can get at least 50% more power out of them without severely impacting long-term reliability and driveability).
The mechanical weaknesses I hear so often regarding subaru's would put me off for life!
plus i've never been a fan of suv's - maybe that will change one day...but for now i'm happy with the stagea.
Edited by pixel8r
https://www.sau.com.au/forums/topic/166418-forester-sti/#findComment-3083089
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
