Hi,
I've just had my car checked out and I've been told that my top camber and caster bushes are pretty much rooted and just wondering what different brands are available out there and what people have in their cars and their experiences.
My car is a daily driver with the odd track day here and there. and its an R32 GTS-T
Any help would be really appreciated.
Thanks in advance.
Edited by G3TFKD
https://www.sau.com.au/forums/topic/166454-front-top-camber-and-caster-bushes/
  simon-ae86 said:
well if you have a 32 or 33 then theres no such thing as camber/ castor tops....
Do you mean the plate at the top of your coilover has a worn bush?
correct. the angle of the strut makes no difference in double wishbone suspension.
sounds like you're being taken for a ride or there's a little miscommunication.
yeh, sorry that was what i meant. its to do with my bushes, they are all worn. are the whiteline bushes good??
whiteline bushes will suit your application nicely.
i (and with many other members) use the same bushes.
I went with Nolathane as the full front end kit all adjustable was cheap as. The full kit was basically the price of just the whiteline upper control arm bushes.
The nolathane bushes apparently don't last as long but time will tell. I've done ~6000km's so far, no squeeks but it has only been 6000km's.
Thanks for the replies.
Also, in the picture, what is the part that I have circled in red with an arrow pointing to it? the rod like thing with the rubber things on the end. is that the tie rod end? it is making a very weird clunking noise.
Edited by G3TFKD
