Does someone know what the Latency Setting is for, as in, what it affects in performance if you get the value incorrect?
Are there dangers, loss of power, emmisions etc???
Reason I'm asking is I've just installed s15, 450cc injectors.
I have them in and running perfectly but i can use 2 different setting on the Latency correction and to me, it seems to be exactly the same (Power FC settings)
I've used :
+ 0.12 and
- 0.06
Negative 0.06 i think is correct using the calculation method in the FC FAQ (thanks Paul!) but i also tried Positive 0.12 as someone more experienced than me already had these little babies in and running on that setting.
Any info appreciated :P
(......and if you're interested in s15 injectors and how they're going, there's another thread in here, probably 5-6 posts away about the info and install)
https://www.sau.com.au/forums/topic/166461-injector-latency/
hey mate i'm pretty sure that the latency is the time it takes to operate the injector ie time its switched on to the time its actually open fully, there will be some lag hence the need for the settings. you could probably have them way out and it may not matter.....? might give it a try.....
as long as you've got the percentages right thats the main thing so it doesn't chuck in too much fuel, it should be ok
From the Motec site :
Injector Dead Time
Injector dead time refers to the LATENCY of the injector in producing maximum flow rate. All injectors require a certain amount of time to open completely and produce maximum flow. The amount of time is dependant on several variables including; fuel pressure, battery voltage and physical characteristics of the injectors themselves. Typically higher fuel pressure or lower battery voltage tends to increase the dead time. This leads to a reduction in fuel flow in to the engine and as a result influences the engine's state of tune.
Hey There,
Sounds familiar =) >> http://www.skylinesaustralia.com/forums/in...=161243&hl=
You'll find its old latency minus new latency... thats the figure you put in.
From what i figure, apart from a setting that might be easier on the ECU, Inj drivers, or coils.... the setting has really little effect.
Batch firing, fires most of the injectors at the back of a closed inlet valve, whole 360' OUT... let alone a handful of milliseconds.
I'm of the belief, it doesn't matter so much.
Cheers
Edited by GeeTR
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
