  • Replies 135
bank details wont work bud, please pm me working bank details... need it without the fulls stop
Hi there,
Just replace the full stop with a space
Regards,
Sherwin
apoligies for the miscommunication mate, all good :)
Not a problem..
Will post off your package ASAP..
You should expect to see it Wednesday or Thursday..
Regards,
Sherwin
is it too late for an R 33 bar.
Hi there,
No it's not too late...
Actually it was perfect timing to ask as more R33 type Lockbars arrived today :)
Regards,
Sherwin
hey im interested in getting one for a r32... do they come with the plugs to block off the lines?? or just the bar?
thanks
Simon
Hi Simon,
It's Just the bar itself, all you will need to purchase is approx. 30cm of Hydraulic Hose and 2 hose clamps to loop the line at the rear :whistling:
Regards,
Sherwin
im also interseted in one for a R32 4 door.
Koree
Hi Koree,
You have been added to the list and Payment details have been sent..
Regards,
Sherwin
Hello everyone,
Just to update those who are interested..
I currently have,
* 16 x Type A Hicas Lockbars
* 23 x Type B Hicas Lockbars
All Ready to be shipped / picked up..
Regards,
Sherwin
I'd probably remove the whole system by looping up near the battery and save about 15kg ;) I removed it all this weekend and installed your bar. You can find further information on the process (with pics)..
here: http://www.nissansilvia.com/forums/locking...13-t185697.html
and here: http://www.skylinesaustralia.com/forums/in...showtopic=93183
I'd probably remove the whole system by looping up near the battery and save about 15kg :D I removed it all this weekend and installed your bar. You can find further information on the process (with pics)..
Hi Gordon,
Thanks for the feedback and the links..
I'm sure i'm not alone when I say it's greatly appreciated :D
Regards,
Sheriwn
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
