Hicas Lockbars - Ready To Be Shipped!
NV N01
 Share
  • Replies 135
hey im interested in getting one for a r32... do they come with the plugs to block off the lines?? or just the bar?
thanks
Simon
Hi Simon,
It's Just the bar itself, all you will need to purchase is approx. 30cm of Hydraulic Hose and 2 hose clamps to loop the line at the rear :whistling:
Regards,
Sherwin
im also interseted in one for a R32 4 door.
Koree
Hi Koree,
You have been added to the list and Payment details have been sent..
Regards,
Sherwin
I'd probably remove the whole system by looping up near the battery and save about 15kg ;) I removed it all this weekend and installed your bar. You can find further information on the process (with pics)..
here: http://www.nissansilvia.com/forums/locking...13-t185697.html
and here: http://www.skylinesaustralia.com/forums/in...showtopic=93183
I'd probably remove the whole system by looping up near the battery and save about 15kg :D I removed it all this weekend and installed your bar. You can find further information on the process (with pics)..
Hi Gordon,
Thanks for the feedback and the links..
I'm sure i'm not alone when I say it's greatly appreciated :D
Regards,
Sheriwn
 Share
    • Welcome Leigh. While it's possible someone knows something about your car, there are so many in the country, it's likely they won't. Either way, I hope you enjoy it and find the knowledge you seek here.
    • Welcome!  Pics of GU and 370z? It's amazing how side tracked we can get with life.
    • G'day. More deets on your patrol? Unless, it's in a d22?
    • So next year I am looking at upgrading from my VE SS bomadore ute to something more refined.  I wanted to stick with a V8 but not anything German or Australian, either a coupe or a sedan. So if I wanted anything newish that limited my options to either the Lexus RCF which I quite like. But with the price they demand and a kid on the way a 2 door coupe is probably not going to be the best idea. The next best thing would be the ISF but the newest models are 2014 and commanding over 60k and even the older 2008 models in ok condition starting around 35k is kind of bullshit. So I figured if I could not have the noise I could perhaps make do with easy power. Enter the infinity Q50 or Skyline equivalent. The price difference between the 300 and 400hp models seems a bit crazy. Right now there is 300hp Q50 one on carsales from a dealer with 61km for 27k drive away. If I wanted to get a 400hp Red or 400R car the prices seem to start at 43k From my limited research it seems that the only differences are that the 400r/Red Red runs more boost and a more aggressive tune. There are are turbine speed sensors on the turbos. Has 2 pumps for the water to air intercooler. Runs an engine oil cooler. I'm guessing that the exterior trims might look a little more sporty as well. I had a lazy look for upgrades to bridge the gap on z1motorsports They have kits that upgrade the water to air heat exchanger as well as the coolant pump which should give a non Red/400r better intercooling temps than the stock Red/400r. I added an engine oil cooler with a thermostat as well to try and make things as close as possible. Obviously the ECU is going to need a tickle. Having not done much in the way of research they also sell a ECU flashing tool with pre loaded tunes that are supposed to boost the non Red/400R by 100hp which adds 1k USD to the cost. The total cost of the parts @ the current time including shipping and taxes worked out to be $4350 AUD. Personally I would rather get the car tuned on a dyno which would probably add more cost Assuming the worst that you got a workshop to install the new parts I would guess no more than 5 hours would be required in the worst case @ 5 x $150 per hour = $750 So the total cost could be around $5100 So for easy number 5k + 27K = 32k I guess that would leave some change left over to swap out the open diff and fit a LSD Any thoughts?
    • Right, not sure why I thought it to be a lean spike. It might be fixable with modern card-style hot film MAFs which have some design features to avoid counting reversion flow but I've never tried it myself.
