  • Replies 135
hey sherwin can i grab another one of the type b lock bars
cheers
Yeah not a problem.. Pm sent with payment details ;)
The list has been updated
Regards,
Sherwin
What exactly do these bars do?
Hi there,
They replace the rear steering rack, present in hicas model cars..
Locking the rear wheels like a non-hicas car..effectively eliminating the rear wheel steering..
Increasing handling at higher speeds :(
Regards,
Sherwin
Hi there,
Regards,
Sherwin
Correct me if i'm wrong, but isnt HICAS there to improve handling?
I was under the belief that Hicas was there to help with parking?
It was only supposed to activate at speeds around 20km/hr etc. for when you are in carparks..
But they have been known to leave the rear end feeling loose during higher speeds.
Therefore, by replacing the rear steering pump with a lockbar, you stiffen the rear end by locking the wheels in place and this increases the handling at higher speeds.
But that is what I believe... like everything, opinions vary :(
Regards,
Sherwin
Umm my understanding is that Nissans' HICAS does not operate at low speeds, only at speeds over about 80kmh and with "X" amount of steering angle.. it is essentially an anti-noob device designed to induce understeer if you come too hot into a corner. Also as it only moves +/- 1deg it's not going to help with parking.
P.S. I'll be wanting one of these in a few weeks :(
P.S. I'll be wanting one of these in a few weeks :)
Yeah no worries.. and thanks for clearing that up for me..
need TYPE A lockbar to suit r32. Please pm me price for delivery to qld $85 total??
and please pm me a approx delivery time and bank detsails.
cheers
cheers
All PM's replied to..
The list has been updated :D
ahhh..
i thought this as well. Activating at above 80km/h
But i thought it was to help with the handling...not to induce understeer -.-;;;;
Understeer is a much less dangerous form of loss of traction than oversteer for the inexperienced driver, so therefore it does help for more experienced drivers.
How much for a bar to suit R32 delivered to 6054?
Cheers.
Hi there,
Prices are listed in the 1st post, but yeah.. $85 delivered Australia Wide
Regards,
Sherwin
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
