hey how far into the western suburbs are you? i live on the gold coast but work in the city....have a gf in coorparoo as well...help a brother out?? :blink:
  • Replies 135
Hi mate,
I am located in the Springfield / Goodna Area.
Regards,
Sherwin
but you come into the city every other day right?
haha ok maybe it's just easier to pay for delivery :rofl:
I've sent you a PM.. I'm sure you will like the solution :blink:
Regards,
Sherwin
you drive a hard bargain....but ok, a blowjob in place of delivery then!
nah that's fair enough, pm replied!
Edited by made_guy
I knew you would like the solution.. :D
PM sent
All PMs replied to.. The list will be updated regularly :D
All Lockbars are still IN stock ready to be shipped..
Regards,
Sherwin
32 gtst still available? will be able to Xfer funds early next week.
Hi there,
Both types are still available :nyaanyaa:
I have sent you a PM with the details..
Regards,
Sherwin
Hi All,
Just to update that there are still Lockbars available in BOTH types :whistling:
I have had a few enquiries for Hydraulic Blocking kits, which would be needed by the A31/S13/R32 Lockbar users, and am looking into offering this aswell :)
I will update the thread with pricing, etc when I have all the information sorted.
And yes they will be available seperately for those who only need the Hydraulic Blocking Kit.
Regards,
Sherwin
Hi there,
That's right mate, you got it in one! :D
These bars replace the rear Hicas Powersteering Pump :)
I have sent you a PM with payment details.
Regards,
Sherwin
Just double checking, this bar fits where the hicas used to. It replaces the hicas if you disconnect and remove, yeh? If so, how do I pay!
hey mate, payment made yesterday for a series 2 R33 Hicas lock bar.
cheers
jaron
Hi Jaron,
You Lockbar has been posted, you should recieve it shortly :)
Just installed mine - went in without a hitch
Thanks Sherwin
Hi Mike,
Glad to hear you like the product :)
Like I said in the first post "Guaranteed Fitment and Strength"
Oh and a update for those interested in the Hydraulic Blocking kits which are required by the Type A Hicas Lockbar users, I should be finalising them on Friday, Hopefully....
So keep an eye on this thread if you are interested in a pack :D
Oh and those who have purchased Lockbars from me, it would be greatly appreciated if you could leave some trader feedback :yes: I have already left feedback for all those who have purchased one :thumbsup:
Regards,
Sherwin
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
    • I'm looking for a direct bolt on turbo upgrade for my 93 R33 GTST.  Anyone have experience with this Greddy T620Z turbo upgrade? I'd like to be able to run about 300hp to the rear wheels without putting too much strain on the turbo. I do daily drive the car.  Pretty stock car with basic bolt ons (exhaust outlet, down pipe, high flow cat and catback exhaust along with intake and FMIC).  I'l probably have a Haltech plug n play on the car before installing the turbo. https://www.greddy.com/products/turbo-upgrade-ecr33-er34-t620z-rb25-11520057   Also, any thought on this much boost on a 30 year old motor with 250,000KMs?  Engine feels/sounds strong for what it's worth.   Thanks you in advance!
