  • Replies 135
hey sherwin can i grab another one of the type b lock bars
cheers
Yeah not a problem.. Pm sent with payment details ;)
The list has been updated
Regards,
Sherwin
What exactly do these bars do?
Hi there,
They replace the rear steering rack, present in hicas model cars..
Locking the rear wheels like a non-hicas car..effectively eliminating the rear wheel steering..
Increasing handling at higher speeds :(
Regards,
Sherwin
Hi there,
Regards,
Sherwin
Correct me if i'm wrong, but isnt HICAS there to improve handling?
I was under the belief that Hicas was there to help with parking?
It was only supposed to activate at speeds around 20km/hr etc. for when you are in carparks..
But they have been known to leave the rear end feeling loose during higher speeds.
Therefore, by replacing the rear steering pump with a lockbar, you stiffen the rear end by locking the wheels in place and this increases the handling at higher speeds.
But that is what I believe... like everything, opinions vary :(
Regards,
Sherwin
Umm my understanding is that Nissans' HICAS does not operate at low speeds, only at speeds over about 80kmh and with "X" amount of steering angle.. it is essentially an anti-noob device designed to induce understeer if you come too hot into a corner. Also as it only moves +/- 1deg it's not going to help with parking.
P.S. I'll be wanting one of these in a few weeks :(
P.S. I'll be wanting one of these in a few weeks :)
Yeah no worries.. and thanks for clearing that up for me..
need TYPE A lockbar to suit r32. Please pm me price for delivery to qld $85 total??
and please pm me a approx delivery time and bank detsails.
cheers
cheers
All PM's replied to..
The list has been updated :D
ahhh..
i thought this as well. Activating at above 80km/h
But i thought it was to help with the handling...not to induce understeer -.-;;;;
Understeer is a much less dangerous form of loss of traction than oversteer for the inexperienced driver, so therefore it does help for more experienced drivers.
How much for a bar to suit R32 delivered to 6054?
Cheers.
Hi there,
Prices are listed in the 1st post, but yeah.. $85 delivered Australia Wide
Regards,
Sherwin
Guest
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
