I went to the 'Dyno B' and got my car
dyno'd. Except i only got about 163rwkw 'Dyno B', unlike 193rwkw which i got at 'Dyno A'.
The guys at 'Dyno B' said that peak power dropped off at about 5000rpm, when it actually
should still be increasing. The only thing i have changed since the first dyno was, i installed a S/S
inlet pipe between AFM & turbo.
The power curve was fine at 'Dyno A'. Have you ever come across this before?
Both dyno runs showed good AFR's.
What would be the more appropriate power output figure for my current mods.
Mods:-
1993 R32 Skyline
RB20DET
Stock internals
5-speed manual
R33 S1 turbo
Trust front mount intercooler
Full exhaust (Split 3' dump/front pipe)
GTR fuel pump
Boost controller running at 14psi
Re-mapped ECU
Air pod
S/S inlet pipe
Edited by lows_13
https://www.sau.com.au/forums/topic/166491-power-figure-issue/
163rwkw sounds realistic
lots of things can affect the readouts, post both dyno sheets
one could have air temp correction, the other might not
one could be in a different gear or different ramp rate etc
Dynos can be calibrated differently therefore showing that some cars have less powerful then they do on a different dyno. The stainless steel intake pipe shouldn't have made any difference as the only problem i've heard of is with the stock plastic one contracting under suction and limiting air flow so if anything the s/s one should be better. my suggestion would be to go back to dyno A and get a re-run on that
most Rb20's with the 25 turbos make any where from 160 to 180 ish rwkw, even more if they are pushed to 14 psi. but for the sake of it we'll assume 12 or so psi.
dont be too fussed about different dyno reads out tho, does the car feel any different on road compared to both dynos?
maybe the stainless inlet pipe has made your car slower/less powerful? I mean if that's the only thing you've changed and your power has gone down... how does it feel to you?
Power feels about the same after the S/S inlet mod.
Theres a lot more turbo sucking sound, thats about it.
The ambient temps clearly show the 2 runs weren't done on the same day, probably not even the same month! Is it any wonder then that you encountered differences. Although I would expect the colder day to produce better power.
Are both dynos the same model? Same manufacturer?
They say that each 3 degree increase in intake air temp makes a 1% reduction in power.
So for a 20 degree (at least) increase in temp thats probably 8% power just there, compounded by the hotter air going through the intercooler...
So more like 10-15% power drop from increased temp and your getting to be in the same ballpark kW reading.
Rhett
  • 3 months later...
im going with the 160 mark because near on 200kw? on 14psi with a tiny 2lt engine?? hahah no chance... not with a standard r33 turbo.. ive driven one of those b4 and damn they are torqueless and slow :rofl: sorry dude but theres no chance urs makin near on 200rwkw
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
