They use GT30R's on alot of drift cars. So if your aiming for 280kw, I think the GT30 is a good choice. i plan on running mine at 255-265kw range and I think it will do the job. Z32, injectors, ecu next week on thursday and im tehre after a tune.
Racecars are not good examples.
DA cars dont see the street. So they have no need for driveability, low rpm response isnt as important.
The tunes dont matter as much below certain RPM generally. Among all the other things that dont compare to a street driven car
  • Replies 92
You dont want the 600hp GT30. I tell you that right now.
It doesnt spool as well as the smaller ones simply because the largest blade GT30 wheel, whilst it flows a lot, but takes a while to get going.
Its not what you want for a stocker engine. It wont be on boost (~17-20psi) till 4500rpm on the street. Simple as that.
If you "must" sit in the GT30 range, you want the smallest offering. The 500hp wheel'd option.
The 600hp GT30 with the big banger wheel will push around 300rwkw (400rwhp) without too much hassle, but dont expect a lot more from it.
30rwkw extra at the most on pulp. Thats largely dependant on how happy the dyno is aswell.
So you want 400rwhp now? Being you really havent thrown a number out anywhere.
You really should get in a 400rwhp car and you'll see its more than a handful for the street, its more traction nasty than friendly which doesnt make for a quick streeter.
lol. You have to "clutch it". Thats a way to move forward fast while your fighting wheelspin.
what are you talking about....boost at 4500 i have a gt3040 .63 ex on my engine no cams.....and i hit full boost at 3800
Man i wish i had all this info when i was looking for a turbo, for a street car theres no need to go for anything past a highflow or a direct fit GTRS or something T25/28 based, like everyone else said response is what you want for a street car, why would you want a lag monster?
You cant go past a direct bolt on for $$ and for performance... standard manifold is fine just look at setups and results from all the other forum members, and if you don't plan on opening up the motor i wouldn't go for a GT30 besides as soon as its spotted by the cops/epa your in for big $$... its just not worth it if its just a street car. If you go track/drift/drag car then i'd understand but its only a st car...
Seriously, listen to the people with experience (i wish i did) save yourself a motor and save yourself some $$ and headf**ks.
True, but I think my GT30R hybrid turbo is great, off boost and on. And regency, IMO tougher from what I hear than any other state, cannot spot them easily at all since its in a RB25 Turbo's hiflowed casing.
It's a good street turbo-kit I got and I think it will be fine at my intended use for it after next thurs & after injectors and Z32 (14-16psi).
You do not have the 600hp version if you have a .63 rear end.
The 600hp is a .82 only as its not possible to get the flow through the small rear
You have the one with the smaller of the comp wheels.
oh fair enough then my bad lol, but the 3040 with the .63 is a weapon of a turbo i love it
A couple of posts up he said full boost by 3,800rpm.Sounds good.Damn,I can`t decide between hksGTRS or 3040 .63 or 3076 or 3071.I do know that I have spent a lot of time and money on my GCG hiflow and still have 220rwkw.
Dan is the man!
Thats about the power im lookin for 240kw - 250kw
Good spool up time thanks to the .63 rear end, 3200rpm to full boost at 3800rpm
And the best thing is the low boost, Less stress on the turbo and the engine.
The GT3040 and GT3076 are the same price at this place i looked, and even on the garret website, so they aint trying to push me for more money on this one. If anything they'd tell me to get the less powered one and wait for me to come back lookin for more power if they wanted me to spend more.
my 2 cents ,having driven gcg 450hp hi flow , gt3076 500 hp turbo with a/r .63 internal wastegate and my current set up gt3040 600hp turbo with a/r .82 exhaust housing.
gcg 450p hi flow gave me 230rwkws on 20 psi at 3200rpm. heaps on low end and midrange a great street turbo.
gt3076 500hp turbo gave me 260rwkws on 20 psi at 3500rpm / 3800rpm. three weeks later the engine let go. then i had the engine rebuilt with forged internals and with the addition of tomei poncams step 1s , she pulled 281rwkws on 22psi this was with 8.5 to 1 compression instead of standard 9 to 1. this combination pulled high 12s down the quarter with crap 2.2second 60 footers on street tyres and 112 mph. a great compramise between street and strip!
gt3040 600hp turbo with .82 a/r exhaust housing, tial 38mm external wastegate and highmount manifold plus ported head now gives me 274 rwkws on 15/17 psi and 347 rwkws at 4400rpm fullboost but you feel the kick in the pants from 4000rpm. yet to try this combo out on the dragstrip but i can tell you that from 4400rpm to 4600rpm the power goes from like 168 rwkws to 268 rwks and its breaks traction 1st 2nd 3rd and 4th gear!!! very peaky bitch in deed. luckily though i can turn the boost down from 24psi 347rwkws down to 15psi 274 rwkws and she doesnt come onto boost as hard. hope this help you out, cheers carl.
jeeze u dont have good luck do you?
Well the engines that come out of Slide's shop are known as the Widow Makers.
I know of 3 other people that have had a rebuild and when done with their new turbo setup they have crashed them aswell. :laugh:
2 possible reasons
Me and the other 3 people cant drive (my fault for the crash and from what i heard from the others definately theirs)
Or
The engines they build are posessed by the devil and make too much power to handle by any man.
Im sticking to the 2nd lol ;)
Allthough they havnt killed anyone yet if it wasnt for my airbag i probably would be lol
Is it possible to get a fancy boost controller that bleeds the boost so it comes on in a more linear fashion ?
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
    • I'm going to run hard lines front to back in the future. That should help dissipate a bit more heat. If not, a fuel cooler might be next
