They use GT30R's on alot of drift cars. So if your aiming for 280kw, I think the GT30 is a good choice. i plan on running mine at 255-265kw range and I think it will do the job. Z32, injectors, ecu next week on thursday and im tehre after a tune.
Racecars are not good examples.
DA cars dont see the street. So they have no need for driveability, low rpm response isnt as important.
The tunes dont matter as much below certain RPM generally. Among all the other things that dont compare to a street driven car
  • Replies 92
You dont want the 600hp GT30. I tell you that right now.
It doesnt spool as well as the smaller ones simply because the largest blade GT30 wheel, whilst it flows a lot, but takes a while to get going.
Its not what you want for a stocker engine. It wont be on boost (~17-20psi) till 4500rpm on the street. Simple as that.
If you "must" sit in the GT30 range, you want the smallest offering. The 500hp wheel'd option.
The 600hp GT30 with the big banger wheel will push around 300rwkw (400rwhp) without too much hassle, but dont expect a lot more from it.
30rwkw extra at the most on pulp. Thats largely dependant on how happy the dyno is aswell.
So you want 400rwhp now? Being you really havent thrown a number out anywhere.
You really should get in a 400rwhp car and you'll see its more than a handful for the street, its more traction nasty than friendly which doesnt make for a quick streeter.
lol. You have to "clutch it". Thats a way to move forward fast while your fighting wheelspin.
what are you talking about....boost at 4500 i have a gt3040 .63 ex on my engine no cams.....and i hit full boost at 3800
Man i wish i had all this info when i was looking for a turbo, for a street car theres no need to go for anything past a highflow or a direct fit GTRS or something T25/28 based, like everyone else said response is what you want for a street car, why would you want a lag monster?
You cant go past a direct bolt on for $$ and for performance... standard manifold is fine just look at setups and results from all the other forum members, and if you don't plan on opening up the motor i wouldn't go for a GT30 besides as soon as its spotted by the cops/epa your in for big $$... its just not worth it if its just a street car. If you go track/drift/drag car then i'd understand but its only a st car...
Seriously, listen to the people with experience (i wish i did) save yourself a motor and save yourself some $$ and headf**ks.
True, but I think my GT30R hybrid turbo is great, off boost and on. And regency, IMO tougher from what I hear than any other state, cannot spot them easily at all since its in a RB25 Turbo's hiflowed casing.
It's a good street turbo-kit I got and I think it will be fine at my intended use for it after next thurs & after injectors and Z32 (14-16psi).
You do not have the 600hp version if you have a .63 rear end.
The 600hp is a .82 only as its not possible to get the flow through the small rear
You have the one with the smaller of the comp wheels.
oh fair enough then my bad lol, but the 3040 with the .63 is a weapon of a turbo i love it
A couple of posts up he said full boost by 3,800rpm.Sounds good.Damn,I can`t decide between hksGTRS or 3040 .63 or 3076 or 3071.I do know that I have spent a lot of time and money on my GCG hiflow and still have 220rwkw.
Dan is the man!
Thats about the power im lookin for 240kw - 250kw
Good spool up time thanks to the .63 rear end, 3200rpm to full boost at 3800rpm
And the best thing is the low boost, Less stress on the turbo and the engine.
The GT3040 and GT3076 are the same price at this place i looked, and even on the garret website, so they aint trying to push me for more money on this one. If anything they'd tell me to get the less powered one and wait for me to come back lookin for more power if they wanted me to spend more.
my 2 cents ,having driven gcg 450hp hi flow , gt3076 500 hp turbo with a/r .63 internal wastegate and my current set up gt3040 600hp turbo with a/r .82 exhaust housing.
gcg 450p hi flow gave me 230rwkws on 20 psi at 3200rpm. heaps on low end and midrange a great street turbo.
gt3076 500hp turbo gave me 260rwkws on 20 psi at 3500rpm / 3800rpm. three weeks later the engine let go. then i had the engine rebuilt with forged internals and with the addition of tomei poncams step 1s , she pulled 281rwkws on 22psi this was with 8.5 to 1 compression instead of standard 9 to 1. this combination pulled high 12s down the quarter with crap 2.2second 60 footers on street tyres and 112 mph. a great compramise between street and strip!
gt3040 600hp turbo with .82 a/r exhaust housing, tial 38mm external wastegate and highmount manifold plus ported head now gives me 274 rwkws on 15/17 psi and 347 rwkws at 4400rpm fullboost but you feel the kick in the pants from 4000rpm. yet to try this combo out on the dragstrip but i can tell you that from 4400rpm to 4600rpm the power goes from like 168 rwkws to 268 rwks and its breaks traction 1st 2nd 3rd and 4th gear!!! very peaky bitch in deed. luckily though i can turn the boost down from 24psi 347rwkws down to 15psi 274 rwkws and she doesnt come onto boost as hard. hope this help you out, cheers carl.
jeeze u dont have good luck do you?
Well the engines that come out of Slide's shop are known as the Widow Makers.
I know of 3 other people that have had a rebuild and when done with their new turbo setup they have crashed them aswell. :laugh:
2 possible reasons
Me and the other 3 people cant drive (my fault for the crash and from what i heard from the others definately theirs)
Or
The engines they build are posessed by the devil and make too much power to handle by any man.
Im sticking to the 2nd lol ;)
Allthough they havnt killed anyone yet if it wasnt for my airbag i probably would be lol
Is it possible to get a fancy boost controller that bleeds the boost so it comes on in a more linear fashion ?
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
