They use GT30R's on alot of drift cars. So if your aiming for 280kw, I think the GT30 is a good choice. i plan on running mine at 255-265kw range and I think it will do the job. Z32, injectors, ecu next week on thursday and im tehre after a tune.
Racecars are not good examples.
DA cars dont see the street. So they have no need for driveability, low rpm response isnt as important.
The tunes dont matter as much below certain RPM generally. Among all the other things that dont compare to a street driven car
  • Replies 92
You dont want the 600hp GT30. I tell you that right now.
It doesnt spool as well as the smaller ones simply because the largest blade GT30 wheel, whilst it flows a lot, but takes a while to get going.
Its not what you want for a stocker engine. It wont be on boost (~17-20psi) till 4500rpm on the street. Simple as that.
If you "must" sit in the GT30 range, you want the smallest offering. The 500hp wheel'd option.
The 600hp GT30 with the big banger wheel will push around 300rwkw (400rwhp) without too much hassle, but dont expect a lot more from it.
30rwkw extra at the most on pulp. Thats largely dependant on how happy the dyno is aswell.
So you want 400rwhp now? Being you really havent thrown a number out anywhere.
You really should get in a 400rwhp car and you'll see its more than a handful for the street, its more traction nasty than friendly which doesnt make for a quick streeter.
lol. You have to "clutch it". Thats a way to move forward fast while your fighting wheelspin.
what are you talking about....boost at 4500 i have a gt3040 .63 ex on my engine no cams.....and i hit full boost at 3800
Man i wish i had all this info when i was looking for a turbo, for a street car theres no need to go for anything past a highflow or a direct fit GTRS or something T25/28 based, like everyone else said response is what you want for a street car, why would you want a lag monster?
You cant go past a direct bolt on for $$ and for performance... standard manifold is fine just look at setups and results from all the other forum members, and if you don't plan on opening up the motor i wouldn't go for a GT30 besides as soon as its spotted by the cops/epa your in for big $$... its just not worth it if its just a street car. If you go track/drift/drag car then i'd understand but its only a st car...
Seriously, listen to the people with experience (i wish i did) save yourself a motor and save yourself some $$ and headf**ks.
True, but I think my GT30R hybrid turbo is great, off boost and on. And regency, IMO tougher from what I hear than any other state, cannot spot them easily at all since its in a RB25 Turbo's hiflowed casing.
It's a good street turbo-kit I got and I think it will be fine at my intended use for it after next thurs & after injectors and Z32 (14-16psi).
You do not have the 600hp version if you have a .63 rear end.
The 600hp is a .82 only as its not possible to get the flow through the small rear
You have the one with the smaller of the comp wheels.
oh fair enough then my bad lol, but the 3040 with the .63 is a weapon of a turbo i love it
A couple of posts up he said full boost by 3,800rpm.Sounds good.Damn,I can`t decide between hksGTRS or 3040 .63 or 3076 or 3071.I do know that I have spent a lot of time and money on my GCG hiflow and still have 220rwkw.
Dan is the man!
Thats about the power im lookin for 240kw - 250kw
Good spool up time thanks to the .63 rear end, 3200rpm to full boost at 3800rpm
And the best thing is the low boost, Less stress on the turbo and the engine.
The GT3040 and GT3076 are the same price at this place i looked, and even on the garret website, so they aint trying to push me for more money on this one. If anything they'd tell me to get the less powered one and wait for me to come back lookin for more power if they wanted me to spend more.
my 2 cents ,having driven gcg 450hp hi flow , gt3076 500 hp turbo with a/r .63 internal wastegate and my current set up gt3040 600hp turbo with a/r .82 exhaust housing.
gcg 450p hi flow gave me 230rwkws on 20 psi at 3200rpm. heaps on low end and midrange a great street turbo.
gt3076 500hp turbo gave me 260rwkws on 20 psi at 3500rpm / 3800rpm. three weeks later the engine let go. then i had the engine rebuilt with forged internals and with the addition of tomei poncams step 1s , she pulled 281rwkws on 22psi this was with 8.5 to 1 compression instead of standard 9 to 1. this combination pulled high 12s down the quarter with crap 2.2second 60 footers on street tyres and 112 mph. a great compramise between street and strip!
gt3040 600hp turbo with .82 a/r exhaust housing, tial 38mm external wastegate and highmount manifold plus ported head now gives me 274 rwkws on 15/17 psi and 347 rwkws at 4400rpm fullboost but you feel the kick in the pants from 4000rpm. yet to try this combo out on the dragstrip but i can tell you that from 4400rpm to 4600rpm the power goes from like 168 rwkws to 268 rwks and its breaks traction 1st 2nd 3rd and 4th gear!!! very peaky bitch in deed. luckily though i can turn the boost down from 24psi 347rwkws down to 15psi 274 rwkws and she doesnt come onto boost as hard. hope this help you out, cheers carl.
jeeze u dont have good luck do you?
Well the engines that come out of Slide's shop are known as the Widow Makers.
I know of 3 other people that have had a rebuild and when done with their new turbo setup they have crashed them aswell. :laugh:
2 possible reasons
Me and the other 3 people cant drive (my fault for the crash and from what i heard from the others definately theirs)
Or
The engines they build are posessed by the devil and make too much power to handle by any man.
Im sticking to the 2nd lol ;)
Allthough they havnt killed anyone yet if it wasnt for my airbag i probably would be lol
Is it possible to get a fancy boost controller that bleeds the boost so it comes on in a more linear fashion ?
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
