Time to sell a true classic
1994 R32 GTR (white)
Full years rego
Will supply roadworthy
Car in Melbourne
Price $ 36,000
I have searched for a around a year looking for a very clean last of the 32 gtrs in stock condition and finally found this beauty, i am the first owner of this car and as you see in the photos it is no longer very stock.
I have driven many R32 gtrs and none of the ones i drove compare to this fine example. There are plenty cheap 89-90 models floating around but most are total rubbish. Why buy a 89 R32 when for a little more you can buy one that is 5 years younger and with all the right goodies on it. Go and drive as many R32 gtrs as you can and then drive mine and make up your own mind.
Anyway the car was stock when i bought it around a year ago and since then it has only travelled around 2000 km's.
All current modifications installed 2 March, 2007 where done by RacingLine Motorsport (Cheltenham)
All parts listed below are all brand new and on the car less than two months and 400kms old.
Apexi Power FC
Nismo Air flow meters
Nismo 600cc injectors
Nismo fuel pump
Nismo fuel pressure regulator
Hks split dump pipes
Tomei Poncams 260 IN/EX 9.15mm lift
Garrett GT2860R-(5) turbos
Genuine Nissan Water Pump
Genuine Nissan Timing Belt
New Tensioner and idler bearings
Adjustable steel cam gears
Extreme HD clutch kit
K&N filter panel
Metal cat 3.5"
Endless super Street Y Sport front pads
Blitz dual SBC
NGK BCP7ES plugs
All fluids - engine, coolant, brake fluid, diffs, gearbox, attessa etc have been replaced with redline/castrol oils.
Airconditioning - compessor has been reconditioned and regased.
Car has spent may hours on dyno to get the tuning right, it currently has 330awkw.
Other second hand parts include:
Tanabe Pro coilover suspension
Full stainless front pipes, cat and rear exhaust
18" X 9 BBS wheels (gold)
Also have most original parts from car.
This car has it all and all engine parts are all brand new and i have all the original boxes for them.
I have all the paper work for the modifications and you can talk to Racingline motorsport to confirm anything done on the car.
If your looking for a genuine clean R32 GTR with all the right stuff, look no further this car will not dissapoint.
Please no time wasters only genuine enquires thanks
Post or call me on 0417 585 573
Edited by arrow
https://www.sau.com.au/forums/topic/166507-1994-r32-gtr-330awkw-immaculate/
RNS-11Z
First you cannot say look at my price without seeing in the flesh what is on offer.
Secondly this is a 1994 model one of the few around and not an 1989-90 model. The car is in great condition and all the modifications listed are brand new and set me back over $15,000.
I know you can get ones for around 20-25k but most are shitters and can not compare with what i have for sale.
Anyway not trying to be nasty, any genuine buyers who see this car will not be disappointed.
And price can be flexible.
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
