Hey guys,
I have been trying to troubleshot my engine problem for a long time now and its finally getting down to a diagnosis and i would love if all u guys/girls could enter your input and effective form of action. PLEASE i am getting annoyed and having WITHDRAWS from lack of turbocharged power. My daily driver. (1.5 n/a just isn't the same)
Details:
93 r32 gts4-t (RB20DET)
2 x bov (stock and aftermarket) - aftermarket disabled
walbro 500+ fuel pump
turbosmart boost Tee
front mount Intercooler
stock internals
stock turbo
auto to man conversion - GT-r gearbox, exedy clutch etc...............
splitfire coilpacks
The problem:
Starts with heistating lead to complication after complications and replacing lots of stuff.
Currently, car cold starts fine revs fine............... then as it gets warmer (not hot but warmer) starts to stutter ( like a half miss) then it starts to miss (sounding like a rexy) missing through the stumbles through the rev range. it gets worse as it warms! I am over fueling, i think
Performed actions in an attempt to solve:
1. swapped coils > SP coilpacks
2. swapped afm with one from a wrecker
3. arm resoldered old one
4. changed fuel filter, installed new fuel pump (walbro)
5. swapped ignitor pack with working rb20det
6. new coilpack loom
7. cleaned aac valve
8. checked and solved vacuum leaks
9. all 6 injectors are clicking - used screw driver to listen for mechanical operation
10. cleaned O2 sensor with carby cleaner
11. changed and regapped spark plugs
12. ECU diag returns two codes> 54 auto trans disconnected (FINE) code 12 AFM voltage over 0.5 volts at idle or greater than 2 volts with idle engine or stalled engine
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Could it be a fried ecu when installing an amp?
Small leak in the head gasket which gets larger as the car warms and causing the misfiring and broad minded persontering
fuel regulator?
https://www.sau.com.au/forums/topic/166539-idlemisfire-caused-by-head-gasket/
how do i confirm head gasket?
and if it is a head gasket should i buy a NEWER RB20DET from a gts-t (mine has had a 220,XXX kms life) and swap the sump with my gts4-t would this work? (i am guessing the only difference to be the front diff and 4wd sump?? anything else)
or should i RECON head, and new head gasket etc which would be a stronger and more money wise
There is a little white smoke at the start when cold.... then it passes! oil doesn't look throthy, but might seem a little less viscose, and the radiator seems to have a little trace or chemicals/oil on the top but it isn't milky.
Blocked injectors are not going to cause this issue.
You havent tried a cam angle sensor but I doubt that will be your problem either.
Instead of trying to diagnosis a problem and having it drag out forever invest the 80-100 bucks a workshop will charge and let them find the problem.
At least this way the problem is diagnosised your not wasting time or money guessing and you have a repair estimate etc from the shop that you choose.
Yeh that is a good idea... it is hard to pick a workshop that won't bone me for all i am worth and that can fine the problem easily and quickly.
any recommendations?? in brisbane CDB/brisbane
GT auto - it already been there
mercury motor sport
STZ automotve
opition1garage
mercury motor sport
STZ automotve
opition1garage
How about your local Nissan dealer, who can hook up the Consult module.
Have you tried a new temp sensor?
Yeah try that sensor
U can just turn the that screw on the standard ECU and it will flash codes at u 5 long and 5 short flashs means everything is OK
I have done the self-diag and the ECU returns......
54 = auto trans d/c > auto to man conversion
12 = AFM
but i have changed the afm and it still returns a code 12 only reason i think it is a heady..... just little specks of black stuff from the exhaust it feels wet but its not wet to touch!
Edited by RipNGrip
This sounds pretty much identical to the problems i'm having with my rb20det in my rodeo minitruck.
Im getting error code #54 as well.
It's got the skyline manual box as well, so i'm assuming that I must have an ecu out of an automatic car.
Be good to see if you fix it so I can fix mine too.
Nisskid: i have swapped the ignitor pack before with no improvement and i should try and pull out some of the coils when idling to see if it makes a different but i been lazy and it revs fine when its completely cold! first turn over so its weird!
loloror: or whatever ur name is . I will post a solution! if they find it.
QUESTION: would a stuffed temp sensor cause these symptoms and won't it come up as a ecu selfdiag code?
  • 3 weeks later...
Well update: I sent the car to mercury motorsport in wilston on newmarket rd. Fixed the problem within two hours, so while it was there i brought a sliding performance high flow turbo, dump pile, fuel pressure reg, and asked them to tune and remap ecu. HEHEHE couldn't help it i have been missing my boost! Apparently, cracked spark plugs which is disappointing idiriums didn't even go 100 kms. Hopefully, i can pick up my car on wed/thur and go for a strap!! wonder how she will go.................................. thinking about injectors now!
p.s compression test was done 165 tpo 175 across the board! :D and she was running lean! lol
Edited by RipNGrip
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
