Hi I have a R33 gtst. My car no matter if its hot or cold will not idle. This is what it does car starts easy, revs to 1900 rpm,drops to 1500, pause, then to 1000 for a sec then dies. Stalls all the time. Runs perfect above 1500 rpm.
I have a HKS Sq BOV.
I have tried so far:
Cleaning Acc valve and all that muck out of the back of the plenum
Repacing fuel filter
setting the TPS
Turning Idle screw in and out with the TPS disconected ( For some reson the IDle does not change 1 bit weather i turn it in or out)
Cleaning out the AFM
Located where the Ecu idle screw should be, to find the isnt 1 on it
checked for leaks
what have i missed? Can someone help me out please!
https://www.sau.com.au/forums/topic/166540-r33-idle-problem-need-some-help/
1. Go back to your stock bov
2. Get a plumb back bov
3. Get a tune
your atmo bov will be releasing a lot of air into the atmosphere, yet your air flow comp will read it as being in the system, so the fuel will be added as if there is that amount of air in there... but its not... any of the 3 will fix this problem... normally an atmo bov wont cause it to completely die at idle, it does create idling and gear changing problems, but not normall this bad... which is why i said get a tune..
anyway, hope one of those fixes it for you :P
the bov i have i think is a plub bak though ( is that where a vacuum line sucks the valve open cuse its one of those) I dunno.
u know any tuning garages on the sunny coast?
thanks
a hks ssqv bov is atmo unless you have the recirc kit. is the plumback line blocked off?
Had the same problem...was running a HKS bov..and the car wont idle properly..only to find theres a slight vacuum leak from the HKS BOV as its a Atmo BOV..i put the stock BOV back and plumb it back into my intake pipe..problem gone..like wat DRD OFF said..the afm is gettin weird reading cos of the atmo BOV..
man what the hell is drd off? :wave:
as for the original poster, you might want to save up some money and get a tune, you will notice that your car will run a shit load better... most well tuned skylines with atmo bovs wont actually stall, but if yours is, its a bit under the weather and could use a check up :wave:
i think you will like the change :unsure:
  • 2 years later...
please try an alternate stock ECU
my old ECU was fried and i drove a car like this for 6 months lol - not fun looking like a tool revving your car at every set of lights.
swap it out and see if you know someone with an stock ECU'd r33
hi guys
May not be the problem but i found info in regards to small cracks/holes in the little vacuum line on the turbo
Also my car played up bad one day turned out the boost/vacuum line to my gauge was leaking a little causing same problems as listed above
I would go round the engine bay with a can of carby clean or start ya basterd and see if there is any leaks else were i know you said you checked for leaks but it dose'nt take much to create a problem
happy leak hunting
setting the TPS
checked for leaks
Make sure your fuel pump dropping resistor is plugged in. If any work has been done on the aerial recently it is possible the resistor plug has been unplugged. It is located in the passenger side rear cavity behind the wheel arch (where the jack is located). It is a rectangular silver item with a 2 pin plug.
Cheers
Ben
You sorta can and you sorta can't. Do some research on Nistune.
Are you running an after market plumb back BOV? What else is installed?
i've also got a hdi GT spec hybrid intercooler, aftermarket coilpacks, a boost controller (only running 10 pound) and a HKS cat back exaughst system.. apart from that i'm stock.. i've checked for leaky hoses and i've tried a different ECU and i've replaced my air flow sensor..
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
    • Cool, I’m just down Sydney today. Not much time to get online.
