Coming To Australia?
just because its listed doesnt mean it's coming to australia.
imports101 put up cars like that to give an idea of what they have access to in japan, if buy chance someone purchases it then yeah it will probably make its way in either as race/rally import or to be complied and licenced (imagine the cost involved in returning it back to stock, labour and parts)
that car would have been listed as imports101 are now teamed together with draganddrift.com to give an idea of what they are sourcing :)
its most likely one of the most hardcore cars i have seen listed on any importer's site, im in love haha
As if a RAW would give a quote or get an import approval to comply that type of car, who wants to be the person to give the bill for returning to stock (after finding all the parts as well) plus if a car that is a "race car" in a true sense who wants to be the person to tell the owner "export or destroy".
Any one can get cars like that and yes I have been involved in sourcing a couple of 10 second cars (mate in Japan sourced the current EURO record holder for 4WD) but no way in hell would I import it under RAWS.
Edited by Guest
AFAIK import101 comply their own cars (under Global Motorworks) so I'm guessing at the end of the day its their call on what they can comply, what they can't and what liberties they can take during the compliance process. Dunno if its worth all the hassle of returning it to stock to bring it under SEVS... with a car like that, it'd be better off as a race import... but... kudos to them if they wanna put the hard yards (and time/labour) in to put it on the road.
i know that its not definantly coming to aus.. thats why i put a ? in the title.. ive been a member of imports101 for a while now and i can say that they are one of the best importers in the country.
  • 3 weeks later...
if you import a car for race/rally amd put the parts out of it in your car you already have can you get in trouble
nope >_< you can even just import it as a wreck that saves the hassle of needing a cams licence to bring it in
  • 3 weeks later...
nope :) you can even just import it as a wreck that saves the hassle of needing a cams licence to bring it in
i was under the impression the only way to do so as a wreck was to cut it in half.
  • 1 month later...
Hello,
They will have the bucket of parts to convert it back to stock already.
They bring them in..change the parts for the compliance agent.
Then after the certificate..they put back the parts..if they are ever asked the question..how did it get
all mod up..they say..that the client wanted some after market bits put on.(Their safe)
Easy..this is how it is done..if you don't know already.
On the way they take out the valuable parts and sell them..and replace with others that are less expensive.
My computer,cams,boost controller,front eye lids(C/F) were taken this way.
This can cause lots of problems in the future..some leave HKS cams in and leave the standard computer on,
selling the after market computer for 500+ dollars or more.
Or in my case.....put back standard cams without measuring shims up....luckily I am not a lead foot.
When I had Poncams installed...they said..some ones been around in here.
24 shims needed replacing...
Anyway..my 2c 's worth.
 Share
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on.
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
