Hey,
I'm just having a few problems I can't seem to get the car to boost past stock boost. 0.4 - 0.5 bar. Any ideas why? I've recently added a Exhaust and a Intercooler and had a SAFC2 fitted, but yet to be tuned.
Current mods are: K & N Pod Filter, Custom Pod Enclosure, Cold Air Intake, Forged Pistons, Strengthen Conrods, Blueprinted, Balanced, Port Polished, Metal Head gasket, Spitfire Coils, High Performance Timing Belt, High Performance Spark Plugs, Gready Turbo Timer, Front Mount Intercooler, Apexi 3” Cat-Back Exhaust, SAFC2, Bleed Valve, 0.8 (12PSI) Bar Boost if I can find out whats going on
Thanks in advance.
Regards,
Aron
https://www.sau.com.au/forums/topic/166583-wont-boost-past-stock-boost/
sounds like there could be a small leak somewhere.. check all hoses & clamps etc.
Just done that, went over the whole car every hose I could see I checked and tightened - still no luck?
what type of bleed valve is it... turbo smart ones are setup like this .... Wastegate <----- Boost T <------ Pressure Source.
I have it on my car and it works great, 90 dollars for a boost T but I think its the best one since it has not been troublesome in the least and its been boosting a bit quicker than the stock solenoid could let the car previously
<----- arrow denotes airflow direction.
Edited by Pauly33GTS-t
could be a leaking exhaust manifold
I put the exhaust on myself recently, cat back only maybe the bolts are a touch lose? Could that cause it?
It's a TurboTech one
Edited by ThugishPimp
boost is a measure of resistance to the air pressure in the plenum .. with a port polished head it may be that you are indeed pushing more through your turbo than previously without the resistence in the head/plenum increasing
I was running 0.8BAR (12PSI) a few weeks ago, but removed the bleed valve until I got the exhaust and intercooler done.
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
    • Cheers thanks for the help mate I’ll see how we go with that one
