hi guys
just curious to figure out if R32 GTS4 calipers were 4 pot or something else?
also, if a R32 GTR is 4 pot or what the difference is between the twp types.
and what the sizes are both rotors?
and what all is needed to upgrade a R32 GTS4 front brakes to a R32 GTR setup?
thanks
chris ;)
https://www.sau.com.au/forums/topic/166584-r32-brakes-question/
GTS4 is a 4-spot caliper, using the same pads as GT-R. The GT-R has cross-drilled rotors, which might be slightly larger diameter (check at dba.com.au). I have found that slotted replacements and braided brake lines provide more than adequate stopping power for a GTS4.
they are slightly different calipers, but use the same size pads. the GTR rotors are bigger, 296mm vs 280mm for the GTST ones. rears are 297mm GTR vs I don't know what for GTST (think they may be 297mm too).
if you want to swap to GTR set-up you will need GTR calipers and GTR rotors. that should be it,.
ok then, if the GTS4 already uses the same size pads as the GTR can i keep my standard GTS4 calipers but use the GTR rotors?
i am under the impression that the GTR rotors are bigger... or are they the same, just slotted? :rolleyes:
I can deff confirm that the rear disc's are the same and the front's are larger in diameter (GTR compared to GTSt)
:P
Slotted no, drilled yes, well some were, either way front GTR disc's are different rears are the same
i am under the impression that the GTR rotors are bigger... or are they the same, just slotted? :thanks:
did you read any of the replies in your thread? I already said:
"if you want to swap to GTR set-up you will need GTR calipers and GTR rotors."
and:
"the GTR rotors are bigger, 296mm vs 280mm for the GTST ones."
sometimes I have to admit I wonder why reply at all...
believe that the GTR caliper is aluminium and GTSt and GTS4 is iron... could be wrong though!
Pretty sure my gtst calipers are alloy, when i filled the paint of the nissan logo it was quite soft and shinny like alloy. mind you this was 5 years ago so im not 100% either :thanks: Ill have to have a look at my car next time im at the shop.
Are you sure?
Im quite sure my GTR Rear rotors are smaller then my GTR front rotors
and:
yes i did see the replies
thanks very much for mentioning that... :)
all i wanted to know is,
since the GTR uses the same pads as the GTST, can i use my GTST calipers but throw in the GTR rotors?
and if it would work?
not too difficult to understand that is it?
thanks very much for mentioning that... :P
not it's not difficult to understand at all.
is it difficult to understand this?:
"if you want to swap to GTR set-up you will need GTR calipers and GTR rotors." to read between the lines a bit here.
edit: lol the blind elk beat me too it.
edit2: yes i'm positive GTR front is 296mm GTR rear is 297mm.
edit3: i'm not trying to be a prick here, but you asked a question, i answered it. you read what you wanted to read and got narky.
all i am after is a simple yes or no to my question
i dont see that anywhere???
no :P
also blind_elk
i do understand that if i wanted a GTR set up i would need the GTR calipers and rotors
but... i dont neccesarily want a GTR set up.
i would rather just use GTR rotors and keep my GTST calipers, if that works
that is what i want to know...
i think chris is on the right track now.
for front brakes:
GTR rotor needs GTR caliper (296mm rotor)
GTST rotor needs GTST caliper (280mm rotor)
the both use the same size pad
for rear
both use the same pad
both use the same rotor (297mm) - yes rears are larger than front. trust me. it's true.
the point that everyone is trying to make is that a caliper is built for a certain disc diameter, it needs to sit at the correct distance from the hub for the disc you are using.
so....if you change discs you will need to change calipers as well
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
