What is the stock turbo?
What is the max boost capacity of the stock turbo?
What is the stock boost level and where abouts is this measured?
What can the boost be up'd to using a manual bleed valve safely without detonating with stock cooler?
What can the boost be up'd to with a R33 GT-R cooler?
https://www.sau.com.au/forums/topic/1666-r32-rb20det-questions/
Guest SadisticRage
Answers to the last 4 questions.
1. Being ceramic wheeled it wont tolerate more than 16psi for long....I have seen one boost to 19psi
2. Stock boost tends to be in the region of 9-10psi measured from the black sensor box on the firewall which feeds back to the factory guage (or aftermarket guage where applicable)
3. This will depend greatly on fuel and atmospheric condition, 12psi is safe...beyond there some will tollerate it, others wont. It has to be remembered that the R32 is 10yrs old now so fuel pumps and injectors are often not 100% hence the varience.
4. With a stock turbo, perhaps 2psi above the 12psi max threshold mentioned above. It is worth considering though that the pressure drop across the GTR cooler often defeats the purpose and a smaller cooler may be more appropriate.
1. The stock turbo is a T3 can't give you information on trims etc as I don't know.
2. The stock turbo can safely run below 14psi.
3. The stock boost level is taken from the plenum I beleive as I have a GTS4 i dont have a factory boost guage. If you are running high boost ALWAYS take the boost guage reading from the turbo outlet as the stock intercooler has a couple of psi pressure drop. So the engine could be seeing 14psi but the turbo would be putting out 18psi.
4. I would not go higher than 12psi with the stock cooler as your turbo would be boosting higher than 14psi and therfore the turbo will only last a little while before the exhaust wheel detaches itself. With 12psi you are on the edge of its efficiency range anyway, so anymore would hurt your power as the turbo starts producing alot more heat than usual and the stock cooler has trouble cooling it to an effective heat range.
5. AS there is only a small amount of pressure drop in the 33 cooler, you can safely run about 14psi no more though.
Make sure before you wind up the boost you get your mixtures checked and also your fuel pump tested.
Regards,
Doc
I was still running rich with approx 14psi - 1bar of boost with the std fuel pump. The Fuel pressure bleed kit sorted it out.
Then I went and slapped on a new fuel pump (see sig) and it made it run really really rich up top to the point where the fuel pressure bleed kit had to bleed that much that the mid range leaned out.
I think it has somthing to do with the boost drop up top back to 12psi and the mid being 1 bar. Need a stronger wastegate spring, to stop the boost drop.
anway with 12psi she made 156rwkw with the af right but the mid range was gutless as it was too lean so i've richened it up a little but overall it does go better for the street.
Apparently if i can hold 14psi all the way through the rev range i should make around 170rwkw, so i've been told.
  • 2 months later...
7-9psi is dead stock. Approx 11psi with exhaust, pod ect.
My car car made just over 11psi at the plenum. Your fuel pump will be ok to handle this sought of pressure but will need to be upgeaded when you want to run a bigger turbo or 14+psi.
Doc
It was done on RPM's DD Dyno.
Same dyno as whatsisname's, freebaggins and that article in the zoom mag about FMIC's on the R33's. i.e the pressure drop across the std ic one.. Remember..
When stock it made 115rwkw.
on 12psi it had the fuel pressure reg bleed tuned so the fueling was perfect. and timing i think was set at 20degrees.
on 12psi with 25deg timing, fuel sorted out perfect af's and fmic i made 156rwkw.
Now with basically stock timing at 15psi it makes 164rwkw so with timing pumped in to it (maybe 25deg) which it won't be good to strap around in summer it probably would have made another 5-6rwkw.
Timing does make a good difference.
Also since then I have done the cam belt which was out one tooth in turn retarding the Cam Timing which would have made it a little more power up top but now it is heaps gutsier down low.
Also the compression is still perfect in my motor (~145+) and there is no oil at all anywhere breathing.
The head has been off before so i image the head has been shaved and maybe has a little more compression due to this.
The fmic didn't make it make much more power, fuel pump obviously doesn't make it make any more power but +3 psi more boost does bugger all as the turbo is past its effiency range and runs out of puff.
Tim did say that it should have made 170rwkw with the motor being in good nick etc.. but i also am running a stock airbox, no cai and stock air filter.
and not to forget stock ecu.. :D
It does feel like it goes heaps harder now than when it was making 152rwkw.
  • 3 months later...
    • Let me assume that the concern over a manual ECU is that the NeoDET that you have was an auto and has an auto ECU. That ECU will not be a problem, but you WILL have to Nistune it. And you would have to Nistune it even if you had a manual ECU, because the turbo ECUs will shit the bed if they do not have all the things that they were told they have to have, to be happy. The big one being the TCS CU, which you won't have in your car. Anyway, with an auto ECU (which I have running my originally auto NeoDET in an R32) Nistune allows you to put in a Stagea image which doesn't panic about the absent TCS, and allows you to override a whle bunch of other annoyances that would otherwise see the check engine light on 100% of the time. Also, you can't wind up the power very far on the stock NeoDET ECUs without Nistune, because the boost sensor gets in the way. Nistune allows you to push that problem much further up the dial. Do you even have the boost sensor with the engine? Without it, you are SOL and will need an aftermarket ECU (or to find a sensor somewhere, god knows where). I can't tell you what the wiring loom differences are in a 34. But what Duncan said above needs to be considered. When you say "loom", does that include the transmission loom? Because you will need to swap out the auto tranny loom for the equivalent manual loom, and get rid of the neutral/park start interlock (basically hot wire it).
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
