What is the stock turbo?
What is the max boost capacity of the stock turbo?
What is the stock boost level and where abouts is this measured?
What can the boost be up'd to using a manual bleed valve safely without detonating with stock cooler?
What can the boost be up'd to with a R33 GT-R cooler?
https://www.sau.com.au/forums/topic/1666-r32-rb20det-questions/
Guest SadisticRage
Answers to the last 4 questions.
1. Being ceramic wheeled it wont tolerate more than 16psi for long....I have seen one boost to 19psi
2. Stock boost tends to be in the region of 9-10psi measured from the black sensor box on the firewall which feeds back to the factory guage (or aftermarket guage where applicable)
3. This will depend greatly on fuel and atmospheric condition, 12psi is safe...beyond there some will tollerate it, others wont. It has to be remembered that the R32 is 10yrs old now so fuel pumps and injectors are often not 100% hence the varience.
4. With a stock turbo, perhaps 2psi above the 12psi max threshold mentioned above. It is worth considering though that the pressure drop across the GTR cooler often defeats the purpose and a smaller cooler may be more appropriate.
1. The stock turbo is a T3 can't give you information on trims etc as I don't know.
2. The stock turbo can safely run below 14psi.
3. The stock boost level is taken from the plenum I beleive as I have a GTS4 i dont have a factory boost guage. If you are running high boost ALWAYS take the boost guage reading from the turbo outlet as the stock intercooler has a couple of psi pressure drop. So the engine could be seeing 14psi but the turbo would be putting out 18psi.
4. I would not go higher than 12psi with the stock cooler as your turbo would be boosting higher than 14psi and therfore the turbo will only last a little while before the exhaust wheel detaches itself. With 12psi you are on the edge of its efficiency range anyway, so anymore would hurt your power as the turbo starts producing alot more heat than usual and the stock cooler has trouble cooling it to an effective heat range.
5. AS there is only a small amount of pressure drop in the 33 cooler, you can safely run about 14psi no more though.
Make sure before you wind up the boost you get your mixtures checked and also your fuel pump tested.
Regards,
Doc
I was still running rich with approx 14psi - 1bar of boost with the std fuel pump. The Fuel pressure bleed kit sorted it out.
Then I went and slapped on a new fuel pump (see sig) and it made it run really really rich up top to the point where the fuel pressure bleed kit had to bleed that much that the mid range leaned out.
I think it has somthing to do with the boost drop up top back to 12psi and the mid being 1 bar. Need a stronger wastegate spring, to stop the boost drop.
anway with 12psi she made 156rwkw with the af right but the mid range was gutless as it was too lean so i've richened it up a little but overall it does go better for the street.
Apparently if i can hold 14psi all the way through the rev range i should make around 170rwkw, so i've been told.
  • 2 months later...
7-9psi is dead stock. Approx 11psi with exhaust, pod ect.
My car car made just over 11psi at the plenum. Your fuel pump will be ok to handle this sought of pressure but will need to be upgeaded when you want to run a bigger turbo or 14+psi.
Doc
It was done on RPM's DD Dyno.
Same dyno as whatsisname's, freebaggins and that article in the zoom mag about FMIC's on the R33's. i.e the pressure drop across the std ic one.. Remember..
When stock it made 115rwkw.
on 12psi it had the fuel pressure reg bleed tuned so the fueling was perfect. and timing i think was set at 20degrees.
on 12psi with 25deg timing, fuel sorted out perfect af's and fmic i made 156rwkw.
Now with basically stock timing at 15psi it makes 164rwkw so with timing pumped in to it (maybe 25deg) which it won't be good to strap around in summer it probably would have made another 5-6rwkw.
Timing does make a good difference.
Also since then I have done the cam belt which was out one tooth in turn retarding the Cam Timing which would have made it a little more power up top but now it is heaps gutsier down low.
Also the compression is still perfect in my motor (~145+) and there is no oil at all anywhere breathing.
The head has been off before so i image the head has been shaved and maybe has a little more compression due to this.
The fmic didn't make it make much more power, fuel pump obviously doesn't make it make any more power but +3 psi more boost does bugger all as the turbo is past its effiency range and runs out of puff.
Tim did say that it should have made 170rwkw with the motor being in good nick etc.. but i also am running a stock airbox, no cai and stock air filter.
and not to forget stock ecu.. :D
It does feel like it goes heaps harder now than when it was making 152rwkw.
  • 3 months later...
    • I drive the Tiguan much harder than the Skyline in all conditions, because it just grips and hooks, unlike the R33 shit box
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
