  • Replies 98
Think outside box alittle bit..
low fuel consumption from the engine, same fuel pressure and volume from the pump = most of the fuel is getting heated in the fuel rail and is then getting sent back to the tank (over pumped), recycled and pumped up again. On a nice cruise the fuel gets 'hot' and the problems unfold. Its not about the pump, more about the the flow rate and the engine just doesn't require that much fuel at very light throttle, so the fuel reg just bypasses it and sends it back.
a smaller pump would have less return flow, but wont have the flow for max engine output. that make sense?
Ok i fully understand the point, I just cant quite comprehend that out of all the 044's running externally in cars today that all these people are having to run a fuel cooling setup to solve the overheating problem?
That said im going to track down a oil cooler and do some mods to it and at least try that option.
Would people suggest mounting it in the boot and running a fan over it or mounting it somewhere under the car?
Edited by SirRacer
ahhhh ANOTHER one of my threads being raised from the dead...
I can tell you for sure that the issue does exist... There would be many people having the same issue that are not aware of their cars that they do not think its a problem and they just live with it...
I PM'd you my phone number.. call me tomorrow after 10pm and i will chat to you about it. You definaty need a fuel cooler OR a voltage droppage configuration that will drop the pump flow on low rpm cruise loads.
On the subject of suitable coolers;
I have a just jap oil cooler core (30 row I think, its massive). I'm not going to use this for engine oil as I now want to get a genuine oil cooler kit for peace of mind. Would this be suitable to use as a fuel cooler?
Or, would it be ok to get a second hand tranny cooler and use that?
something like this: http://cgi.ebay.com.au/Oil-transmission-co...A1%7C240%3A1318
My plan is to mount it across the spare wheel well, with a thermo ontop next to my surge tank. Because the core is so large, will it have any problems pumping the fuel through the core and up into the surge tank?
Edited by gibbau
hey bud
that oil cooler you linked to ebay will be PERFECT for the job.. the just jap oil coolers aint too bad ... i use one.. you just need to make sure they dont leak and sometimes you need to mod them.. in my case i just got the fittings put into a lave and removed the ring for the o-ring and replaced them with a copper washer.. NEVER leaked again and it works a treat!!!
get tha oil cooler from ebay and use that as a fuel cooler, its much bigger then mine was and it will work great! i promise you this... use your just jap cooler as they aint too bad as long as they dont leak, if it does leak then DONT replace it just fix the leak.. then they work pretty damn good!
Good luck with it.
hey bud
Good luck with it.
Thanks for your input :worship: I've just heard way too many stories about leaking lines destroying engines and whatnot from china kits.
I'm a fitter and turner apprentice so it's no drama to mod the o-ring.
I'll give it a go and keep an eye on it
Hi all , I just read through this whole thread and a possibly silly idea occured to me .
Some late model cars don't have a return line from the engines fuel rail at all and I had to ask a long time mechanic mate of mine how such a system could possibly work .
He claims that they do actually have a pressure regulator and return but its close to the pump so possibly in tank ?
So me thinks what would happe on a conventional fuel injected car like an RB powered Skyline if the fuel pressure regulator was moved to a "T" piece a little short of the rail itself .
My thinking is that the heat is conducted from the manifold to the rail (or hot ngine bay) so if you could have a return supply system with one side of the T heading to the rail and no rail return do you get around the thermal issues .
The unknown is how hot would the fuel in the rail itself gets and what if anything the manufacturers do to get around it if it is a problem .
One things for sure , if in a hot state you stood on it the supply of fuel comming down the line should be cool once that in the rail had been used .
If this system is workable it should be reasonably cheap as all you'd be doing is moving the reg and adding a T piece and short runs of new EFI hose .
Thoughts ?
Cheers A .
i mounted my fuel cooler back in the car today. in a different spot so i can run a air con condensor fan as well.
will connect it back up to the fuel system next week, it just needs to be connected all the fuel lines have been run etc etc
The simplest way would be to reinvoke the factory system of lowering the pump voltage when not needed... this is obviously one of the reasons the factory do it in the first place, and we all go and rip it off. So way not use a spare output to controll your own setup of a relay and resistor. You could experiment with what size resistor will maintain the flow needed below your chosen rpm (since bosch flows more, it may need less volts at low revs than the stock pump needes to maintain pressure) ...
A correctly working two stage system is the best soloution , no coolers required.
Gary
my car also had these issues running twin external 044s and 2 in tank pumps feeding the surge tank. Not too noisy until about 45 min into a drive on a hotday and the 044s would whine like crazy until it cooled down and then they are fine again. Im gonna look into the fuel cooler setups now, just wondering what sort of dimensions are these coolers u guys are using?
i just used a small tranny oil cooler, its not very big but it does help the system go 3 times longer before the pump starts to complain.
For the record, my 040 intank has done the same.... noisy as hell after a dyno session and slow drive home..... its been quiet when cool. i guess since its submerged its cooled for longer, however the dyno session heated up the fuel alot .
I'll wire the two stage back in, modified of course to provide full power when switched to direct.
Gary
so whats the benifits between using an ally oil cooler or proper copper fuel cooler or tranny cooler? any differences? i assume the fuel cooler is made for the high pressure side, they look like a copper tube in an S shape and fins around them. Ive even considered the moroso fuel cooler setup as well, but they are pricey compared to other options.
Have you heard of this sort of issue being common? Spoke to a Race Car builder yesterday who says he hasnt come across this problem at all when building RB powered cars. Another two mates have 044 powered setups running exactly the same system as me with no problems at all. All rail fuel was being returned back into the surge tank.
I wonder if its just the way the fuel lines are run or something in the RB's?
if you wire the 2 stage back in, will it be enough power to run 2 x high pressure pumps?
Obviously not the std setup, but a custom setup would work fine. I'm about to swap out the 040 for a walbro over the chrissy break, so i will have a look at the wiring and work out a way to wire an external two stage setup triggering off the stock one and get back to you , with a drawing and all if anyone is keen.
Obviously i can't say definitively what voltage the "low" setting has to be, until i get an idea what each pump needs to work at minium load setting, then i can reccomend a resistor to suit.
I'll come back with some definate info later on. And if there is interest i can whip them up to ease install for those not into electronics/ electrical etc .
Gary
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
