hahe i love it, thats awesome. As it would be nice to be able to have it lower the flow, and not heat the fuel so much when idling through traffic.
Course... as long as it never accidentally doesn't flick over, and you hit max boost at 7k rpm with low volts and half fuel flow... :P
that could be ugly, it would go from 13.8v from the relay to 10.5v from the modulator im gonna have a led next to the boost guage to monitor when its on, its got separate adjustable cut in cut out so it can turn on above 8psi and off below 2 psi to make it stable.
  • Replies 98
HOW GOOD!!!
I want.. how do you hook this up to my car? i use AFM ?
ok so it probly is hot fuel you could measure the return temp to prove it.
I ran 8g from the battery to a distro block in the boot because the stock wiring was only supplying 10.5v to the pump so now it gets 13.8v at the pump.
The gtr pumps 270 litres per hour at 14volts and will maintain flow up to 30 psi boost [according to tests done in the uk with a few different pumps]
So its no slouch but in a stock gtr it only gets 10.5 volts max and 5.5v at idle/ low demand, the manual says its to save power but i think the heated fuel in traffic had a part to play in too and 10.5 v is ok at stock boost
I got an adjustable voltage sensing relay from jaycar to connect to the map sensor for the sub meter boost gauge that will switch in a relay on the earth side of the pump at high boost but still allow the modulator to control the pump speed at idle/low loads and keep the fuel cool.
oh some more testing done today. drove from the central coast to the end of the freeway and the noise started (tank was close to empty) before i got to the servo it was getting noisy again... put $40 in and then it went back to normal sound and normal a/f ratio's and did not make any noise all the way to work.
So its definatly fuel temp issues.... I am convinced.
Guilt Toy..
There's definitely something up as on a day like this myself and mates definitely don't have fuel temp/noise issues even when running on empty *red light on*.
Our pumps only start making noise on warmish 30degree+ days.
Have you tried pointing the return away from the pumps pickup? Maybe your aerating the fuel some what which shows up when low on fuel?
I am using the stock setup. using the walbro pump to pickup fuel and feed to the 044 then the 044 push's to the front of the car.
I have not changed the pickup or returns at all - its all stock
Guilt Toy..
I rang John and he has a stock z32 oil cooler runnong on the return line at the rear of his car in the wheel arch with an air duct.
I am going to run one on the return line at the front of the car. Cool the fuel going back to the tank... would think it would be better to run it on the way to the engine as i can see it giving a better burn that way but its under pressure there....
have you taken it to sydney traffic ? sometimes you can be at stop start traffic and not going above 30 km's an hour for 30 minutes at a time... I dont have issues when i am boosting around the streets at home its just in very heavy traffic.
Guilt Toy..
I have the same setup, intake lift with the external. Regardless if its an empty tank or full take I still get the noisy pump when the amb temp is warm, empty tank noisy fuel pump then fill up, its quiet for 5mins or so then gets noisy again.
We have a little stretch heading home where you sit jammed in traffic for a good 30mins and you literally move a couple of car positions then sit for another 5mins, this repeats for a good 30mins; the only difference being your lucky to even register a speed on your speedo. I would say its comparable.
Pointing the return away from the pick up is a suggestion that others have said they have had good results with in reducing the noise of the pump on those warm days.
Its only a suggestion that may save you a couple hundred. :S
well i can only bring it down to fuel temp. when it makes noise the fuel pump is pretty warm.. this morning after i put half a tank of fuel in the car there was no noises and the pump was cool.
What else could it possibly be ?
sounding more like fuel temp problems, like i said mine does exactly the same. Only thing i don't get is why other people are not having the same problem. Every man and his dog with a skyline has upgraded the fuel pump but only a handful are suffering these problems.
Is it possible we are "over Fuelling" for our power levels. i'm only making 350hp at the wheels at the moment. perhaps i'm pushing to much fuel to the engine bay and just not consuming enough and thus with the large amount of fuel returning to the tank the fuel in the tank just gets to hot.
anyways good luck with the fuel cooler.
I was told to put it on the return line... but i would love to be able to put it on the other side for performance gains ;) not that it will make much difference
Yes this is correct - use the return line as the pressure is much less. You'll be surprized how effective this is, I run a small Perma-cool power steer cooler on my return line (at the front) and the surge tank is way cooler, no more fuel heating issues for me.
Id say it is heat related, maybe the fuel when hotter, cavitates more easily into the pump.
I would say both making the fuel cooler or changing the angle of the return line would work.
Seems strange some people get the issue and some don't. I would have to say, it must be due to small differences in installation angle, depth, running original sock filter etc etc.
HOW GOOD!!!
you can use a gtr boost guage sensor, beer baron had a couple of gtr boost sensors for sale a while ago
you could go back to the stock setup [dropping resistor and relay] and wire another one in parrallel for the 044 except connect the negative to your wire direct from the battery
i dont know when the ecu decides to go to high flow, probly airflow or throttle position or both.
Just thought I'd chime in. I have had the same exact problems with the 044 pumps on my Porsches. After lots of trial, error, browsing the internet, etc I finally determined what was causing the fluctuating whining is heat related. I'm not saying this is necessarily the problem for everyone experiencing similar issues with these pumps. Both of my current Porsches have external pumps, and they are mounted in areas that receive poor cooling and limited airflow. I have noticed with mine that, sometimes they will be relatively quiet and consistant, but usually they start to whine a bit louder and sometimes in a fluctuating manner after I have been driving either car for an hour or 2 and especially in slow/heavy traffic. Voltage fluctuations to the fuel pump are another possibility as well.
Okay i did more testing... and i am 100% sure that its fuel temp issues because yesterday arvo the pump was making very loud noises so i pulled into the servo (had low fuel) left the engine running and poped the boot so i could hear the pump and put in 40 litres of petrol.. as soon as i got up to around 15 litres of petrol the noise completly went away and it sounded normal.
So the extra fuel cooled down the system and i could even feel a temp difference when touching the pump.
i am going to try find a decent oil cooler and put it onto the system this weekend and see how it goes next week.
Guilt-Toy...
So is it the noise your worried about or the afr's going to shit when the fuel pump gets noisy?
Exactly what drivability issues do you experience? Light throttle surge? Idle lean missfire?
As I mentioned earlier (i think) :) I have been experiencing a few light throttle surge and idle lean missfires. BUT it occurs randomly; most of the time with the fuel pump noisy but also a lot of the time when its quiet. Putting fuel in does make my fuel pump quiet as yours did BUT it doesn't make a difference if the afr's are playing up on light throttle/idle. Does yours?
the car was idleing on 17 to 18 afr and when the pump cooled down it went down to around 15.5 (which is still leaner then normal) and it was still missing a little on idle....
on cruise when the pump is noisy it does surge alot and runs pretty lean.. my tune atm is set to around 14.5 - 15.5 on cruise when the pump gets noisy it goes up to 17 +
oh and im worried about both issues because one the noise annoys the shit out of me and 2 the car drives kinda rough when it leans out that much and its annoying too.
Boost is still normal afr's
I have a wideband afr meter in my car at all times now and thats what ive noticed.
Guilt-Toy...
Edited by Guilt-Toy
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
