As per the topic who makes the best caliper adaptors for the HCR32, ive checked out UAS site im just wondering if there is others.
Also who should i order some braided brake lines from, im thinking maltech?
Lastly what would be the best fluid for the circuit?? Not endurance like track day stuff. Was thinking some ap racing stuff from somewhere lol
Thanks guys
>_<
Edited by 2630GTS
https://www.sau.com.au/forums/topic/166619-best-caliper-adapters/
The R32 UAS brackets are one piece. (280-324mm) The R33 are 3 pieces (296 to 324mm)
I have used the same setup for about 6 years and i dont think you will find a better arrangement without spending 3 times the money.
I also use RBF600. Its cheap so i make sure i regularly flush through 300ml. Its overkill but brakes are important and when the wheels are off the car i will give them a good flush with a full bottle and check the pad wear. The fluid is always clean so doesnt need it. I just do it as a regular inspection as i don thave anyone service my car regularly...so need to keep an eye on things myself.
You could use the much better Castrol fluid and get away with less frequent flushes. The stuff is around $120 a tin from memory. I have never used it, but it i know plenty of people that do. The only other fluid i have used has been the AP/Lockheed 5.1 which was good, but more expensive then the Motul
Thanks for the reply Roy, ill give the rbf600 a try first up. Is the brake balance affected much running larger front discs, does anything need to be done with the master cyclinder? My car has ABS if it makes and difference.
Cheers
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
