as ive said before, serious offers considered not rediculous wanabes,
please dont be indulting, u can see the work/ effort gone into this set up,
it was not cheap to do, it is not a cheap set up,
thick wall manifold etc.. will not crack under first sign of boost.
its a lasting set up nort a cheap throw away.
ta
  • 5 weeks later...
