hey guys im not to shore if this has been asked before but i was wondering weather r32 or even r33 brake calipers and front hub assembaly fit or can be moded to fit the old r31 or if anyone has done a brake upgrade what did they use?? maybe even a 5 stud convertion to make tyre choice easer. any help would be great
thanks. Daniel...
https://www.sau.com.au/forums/topic/166650-r31-brake-upgrade/
There are alot of options. Your best bet is to get onto r31skylineclub.com and do some searching.
good or you can ask me i got a 31 too.
im going to be doing a R33 gts-t brake up grade very soon (just getting cash).
you will need the following:
R33-gts-t calipers (there 4pot and will be wildly avalerle here at sau)
R33 gts-t disc (req DBA sloteds)
custom made brake lines (req braided) there is a company that does them that are adr aproved.
r31 gts or HR31 stuts (lower 1/2) this is because the caliper (on r33 ) mounting points are futher apart then the r31 items.
all up could set you back a $1000-$1500 depending on how much the struts and calipers cost.
the brake lines are apx $200 a side.
chears brentt
p.s. you can then fit 6ot brembos if you have the cash
yeah. thats how i did mine on my dr30 rs. (same strut) machine off the disc to make it a hub. then i used a dba 330mm commodore disc (blank) got it drlilled to suit.
same as the above kit but i needded 10mm spacers to achive the corect offset for the caliper/disc combo. and this all fit behind 16's looked cool. just all brakes behind em :laugh:
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
