who cares about monetry value, i love chopping mercs, commodores, falcons, occasionally an audi too...
the look on their face when they get chopped by an old import is priceless!
wanker in SLK55 darting through traffic, revving his V8 that sounds lik a toilet flushing..... gets chopped by a skyline at the next set of lights.......
funny if you ask me
https://www.sau.com.au/forums/topic/166663-evo-ix-2007-rs4/#findComment-3086127
personally i think the soon to arrive new rs6 is where its at. It has the v10 lamborghini engine from the gallardo THEN they added two turbos.
Estimates place power in excess of 400KW and 750Nm.... now THAT IS IMPRESSIVE!!!
Edited by r32line
https://www.sau.com.au/forums/topic/166663-evo-ix-2007-rs4/#findComment-3087661
I hate stupid comparision,
Just like a long time ago, the guy in TOP GEAR compared an R33 gtr with a Mc claren F1 road car, what a dumb c**t. If anyone notices he always favour Britis made cars. I wish i could talk to the short minded face to face.
He did that to show just how fast the F1 really was. The GTR was used as an example of a very fast car. He needed a bench mark to show how much the bar had been raised by the F1 which was only surpassed again recently by the Veyron. Personally I was stoked that they used a GTR as the comparison.
https://www.sau.com.au/forums/topic/166663-evo-ix-2007-rs4/#findComment-3087854
a stock mclaren is going to hose a stock r33 gtr.
*waits for the " such and such's 700kw gtr would kick it's arse"
and my response is, possibly, but i bet that at above 200kmh the maclaren would pull away because the aerodynamics of the gtr aren't designed to let it go up to close to 400kmh.
funny if you ask me
but if i had to drive from brisbane to sydney i'd much preffer the SLK55. and unless you know that the person in the other car is 100% trying to win, how can you say you chopped them. they might have been using 50% throttle and just hoping that there was a cop waiting around the corner to get you.
i like skylines. they are a great car, but they aren't the best car. but at the end of the day, if you spend $100,000 making a skyline as fast as you can, or buying a car for $100,000, the resale on the $100,000 is going to be way better, and it would probably be much nicer to drive, and much more reliable.
https://www.sau.com.au/forums/topic/166663-evo-ix-2007-rs4/#findComment-3087923
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
