Not sure if this has been posted, but just noticed that the 2007 Gumball 3000 has started..
From London to Asia and BACK!!!...
Should be interesting, already had trouble with the German police setting up roadside checking stations JUST for the gumball cars..
Best advice, check out the forums, as the main website is RUBBISH..
http://forums.gumball3000.com/viewforum.php?f=11
You can track their progress on http://maps.google.com - put this link - http://www.rallybird.eu/blog/ftp_incoming/...l%20Day%201.kmz - in the "search maps" area and click search.. it will load it and display their GPS markers..
Should be exciting, def looking forward to seeing some of the footage to come out of this years...
Maxamillian is a Jaguar XJ220S which is an interesting choice, doesn't seem to be any Jap cars this year.. someone should run a R34 GTR in it!!
https://www.sau.com.au/forums/topic/166682-gumball-3000-2007/
They have something similar on this year, starting Brisbane, if I can find it i'll post it up..
Just found this:
And finally, with 2008 being Gumballs �10th Anniversary� the event is already rumoured to be pushing the boundaries of entertainment even further with an incredible 3000 mile route of flying and driving from London to Moscow and onwards to finish in Sydney in 8 just days � it�s going to be HUGE!
So look forward to next year if this is Sydney as in Australia Sydney :)
I posted a link in the Vic section:
http://www.skylinesaustralia.com/forums/in...howtopic=166708
There are also photos from when I went in 05 on here somewhere too if you search.
Route here:
http://www.alk.com/gumball/route.asp
should do one in oz say brisvagus to melb :laughing-smiley-014:
gumball 3000 is like 3000 MILES not 1900 kms i drove from brissy to melbourne in 14.5 hours once dude. wouldnt that be great all these rich mofos come in their ferraris and lambos and shit and drive for approx 10 hours (going by the footage i have seen on the net of guy doing some seriously stupid speeds) and then they get to the end and have their lil party get back on the plane and go home all over in one day that would be really really gay imo
It has been suggested that it would come to Australia for the 10th anniversary and go from Darwin to Sydney. This was before the speeds were reduced in NT though. Oz is a long way from anywhere else and when you consider the idea of the event is it is completed in around 7 days.
and then receive the speeding tickets that were issued by the million or so speed cameras that operate in victoria. :)
http://www.gtspirit.com/
Some great updates..
Update 18:01 CET:
Steve just messaged us that team 25 had a chance to put their foot down in the Carrera GT on an amazing bit of highway in Greece without any traffic. They reached over 200 mph.
not holding back I see..
Hmm.. I can feel the carefactor:
Update: Locals got injured in the crash, we hope they are ok. Our thoughts go out to them and their families.
http://forums.gumball3000.com/viewtopic.php?t=2584
Gumball 3000 has been cancelled after the death of a Macedonian on the roads who's car was hit by a gumballer..
Press release
From the main page:
Issued by Maximillion Cooper on behalf of The Gumball 3000 Rally - 21.30 / 03 May 2007
Following our earlier release reporting yesterday’s accident - As a sign of respect we have decided that this year's Gumball 3000 Rally will not travel any further and will end in Bratislava this evening, May 3rd 2007.
As the organisers of the rally we feel that it should be stopped as a mark of respect to Vladimir Cepulyoski who died today after an accident involving one the participating drivers.
We are very saddened by what has happened and feel that it would be wrong to continue. On behalf of Gumball 3000, we once again extend our deepest sympathies to his family and we are doing everything we can for them.
This is the first time anything like this has happened in 9 years of travelling through over 40 countries with 1000's of drivers and it is with deep regret that I make this announcement.
Maximillion Cooper
Founder & CEO
The Gumball 3000 Group
For any media enquiries call Mission - 02074916680
Another sad loss of life..
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
