been having problems, on n off one...when its a hot/warm day n i go over the bumpy roads ..my indicators stop working and the light stays on constant when i apply indicator. Does anyone know where the repeater box is???
Have stopped car and then just turn key to reds and they start working again then stops n does the same thing after min or 2 or when i start the car?
Could the alarm cause this as well???with a loose wire?? thanks if any input.
https://www.sau.com.au/forums/topic/166684-indicator-r32-gtr/
  • 2 months later...
My indicator blinks really fast, but only to the left side. Right indicator works normal.
Not too much of an issue, but would like to know why.
Does anyone know where's the relay? or what could be wrong with it?
Check to see if you have blown an indicator light. That is the usual reason.
Found out why....my indicator lights on one side started to blink faster on one said and was doing this intermittently checked to see if one was blown globe...but none was blown cause my alarm when i activated them the bulb would work still. So took the front blinkers off and found that one of the wires on the right side blinker was exposed so fixed that with insulating tape and problem solved.
