Re dyno'd my GTR yesterday, totally different power curve :)
Made top power about 6000rpm
166kw's in 4WD & 185kw's in RWD
Graph coming....
check last post
Hey people,
Had my R32 GTR on a Rwd dyno today, it made 176kw's. Not sure about the rpm level, but it made peak power at 101km/h. The only mods so far are a K & N panel filter and a TRUST 80mm cat back exhaust system. Apparently the boost restrictor has been taken off?? bcos it was running a solid 12-13 psi. Is this about right? Anyone roughly know what kinda power increase's a full exhaust system will make.. Any suggestions on next mods.
cheers
Jono
GTR 032
https://www.sau.com.au/forums/topic/16675-my-gtr-on-dyno-today/
I think you're mixing up the torque and power lines Dundan.
Power is the red one, and rises gradually to ~175kw and stays there until redline.
Torque is all over the place. Weirdest torque curve I've ever seen. What's with the dip at the start?!?
In fact the flat power curve is very very weird too...
That's one weird-ass dyno reading right there. Stick with Dyno Dynamics :)
/me writes down "MDXDYNO... Never use".
The dyno guys didn't really say too much about it, get what you pay for I guess... Gonna try a little more reputable dyno next time. The power curve on my GSR was very straight forward to read compared to this one, except that it had bags less power..well not that much :)
Cheers
One weird looking dyno graph!In fact,the power curve looks a lot like the torque curve.I mean, when was last time anyone ever saw power curve dead-flat?Definetly looks like torque.And torque looks very much like the power curve.Except it peaks too early and drops-off too quick to be the power curve.Strange.Could be that the dyno parameters/software were not set-up correctly before the run or something.One weird looking dyno graph.
that is seriously confused. Sure that wasn't made with a spirograph? ...sorry. But it is a weird graph. Use search, and look for 'dyno' - there are may of the guy's dyno sheets on here and you'll probably be able to find a 32 GTR dyno sheet somewhere to compare it to :)
Is that the wheel spinning run? That may explain the apparent power loss. Also that torque figure looks a little unrealistic. 32/33 gtr pull 350-360 Nm at around 4500 rpm stock.
Just remember that power = torque x revs. So as torque drops and revs rise power stays flat.
My guess is wheel spin (and the values are too high). What you've got there is wheels breaking traction at 100kms as the torque ramps up and the correction values on the dyno giving a very high reading.
Cheers
(Professor) BHDave
I'm with Dave, that's the sort of result we get when there is wheelspin. The resistance at the rollers gets to a certain point and then the tyres slip on the rollers. So it always shows the same max power as the wheelspin increases and holds the readings constant. It can be bad enough to affect the power readings, but not bad enough to smoke the joint out.
The torque readings are being affected by being in 3rd gear, that may be the reason why they are higher than usual (in 4th).
I'd suggest another run but in 4th gear and tied down better to the dyno.
Hope that helps
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
