i recently read a post on this forum where a member was stating that his PSI level had rose from 7psi to 9psi just by installing a FMIC ..
how exactly does this occur when the stock ECU still has a boost soleniod setting of 5psi low and 7psi high
https://www.sau.com.au/forums/topic/166768-fmic-increases-psi/
The factory smic is restrictive, thus if you where to measure the boost b4 the smic it will be higher than the boost after the smic. Installing a better flowing cooler will have less restictions, therefor the boost b4 and after the cooler will almost be the same.
The factory solenoid is similar to a bleed valve, as is calculated/manufactured to allow the turbo to boost up to 9psi. This is with the restictive smic, replace with a fmic will reduce restriction, therefor flow more air.
based on my experience with silvias the factory cores have on average a pressure drop of about 2-3psi an aftermarket one has on average less than that and the average differrence in pressure drop is realised as a boost increased.
this also depends on where the actuator gets it signal from
on the r32 it comes off the compressor cover so it wouldnt be an issue on the 32
but the r33 gets it post intercooler so its after intercooler core drop
Pressure differentials across intercooler cores is based on airflow more so than boost pressure. Its just that higher boost pressure usually means more airflow. So your figures are a little ambiguous.
if an intercooler is a restriction then the pressure will be higher before the cooler than after. the more of a restriction the higher the difference.
it's interesting, because we all not that standard boost for an RB20 is 10psi, and standard boost for an RB25 is 5/7psi... but they're measure from different locations...
but if we were to measure them from the same place we might get similar figures. Just thinking out loud.
You won't as the r32 actuator is rated to open at a higher pressure.
Grab an r33 actuator and r32 actuator; the r32 actuator is considerably stiffer.
You shouldn't really get a pressure increase at all!
The same pressure is hitting the solenoid, at 7PSi before or after the intercooler change.
Alot of people actually notice a pressure DROP (If pressyre taken before intercooler) due to a more affective cooling intercooler (Pressure is dependant on temperature too!)
And if the actuator gets it's pressure from AFTER the intercooler, there should be ZERO change in pressure.
If the actuator is set to open at 7PSI with x amount of air bled off, then it will open at 7PSi after some air is bled off.
I was just wondering to myself, if Nissan would have compensated the pressure drop into the adjustment of their actuators, but then I wondered where WE are measuring boost from, so that probably comes into play. But hey like you said the r32 actuator is stiffer anyway so there you go... (still thinking out loud)
LOL...ah, now you agree with me. I remember you thinking i was on drugs when i was commenting why R32s make more boost at the inlet after a fmixc install :(
hmmm....fmic = MUST more driveable car with more consistent results. cold nights also make a BIGG differnece where as before was always crap by comparison. split front / dump 4psi increase with stock controller..... *yeS*
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
