  • Replies 185
Posted Images
missed me shaney poo...
i still can rev 2500rpm higher than that... :(
.... BITCH.. i could say something like at least mine drives lol
mmm stable healthy oil pressure.. :D
yes about time.. i wanna see 12s before i get my R34 GTT.. cause ill be seeing 14s in that :D
i'm laughing out loud right now....no seriously, really hard. You reckon you can rev your standardish 32 GTR to 10k safely?? I wanna see pics/vids of this....
I apologise to Noel because this does belong in another thread....so mark I challenge you to create one and tell us the mods your car has that allows you to rev to 10k??
I'm a puritan at heart Ben. Whilst the 30 bottom end does have some appeal I much prefer the idea of having a hot 25 in a 33 st. Theres something bogan about dumping an outsourced engine in any car to my way of thinking. Sorta makes it a mongoloid hybrid . Even in the old days when i ran holdens it was accepted that the chevys were the better engine but ford had the stronger drive trains. It was common to fit top loader boxes and 9 inch ford rear ends to the holdens to get some reliability but i couldnt bring myself to do it.
I persevered with the bowtie product till I made it work and was more satisfied for doing it.
The other reason is the aussie underdog thing. Whilst most opt for the 26 or the 30 I think there is a ton of potential in the 25.
The only limitation at this point is in cam selection and i think that can be overcome as well. After all, making horsepower is all about getting air fuel in, burning it and getting it out efficiently. With the right cams I see no reason why the 25 cant match it at least with the 26, we are only talking 100 cc's here. Less than 5%. Given that most 26's are pushing an awd system and are inherintly heavier as a result of it i think that pound for pound the performance bar should be on about a par. It might be different if we were talking about mega power in the 800/1000 hp range Where the 26 valve train can be taken further but we are dealing in street/strip cars here.
Hey noel so have you got any ideas or eyes on specifics on valve train, did you get any info on converting to solids and what not? did you find any prices
Edited:1130pm :P
Oh Here is something you might like some new tomei 10.25mm lift spring kit
http://cgi.ebay.com.au/New-Tomei-Valve-spr...1QQcmdZViewItem
Ive dealt with these guys before and there not too bad noel
benjamin (lol) linked me to this site the other nite, 50% off speedflow fittings!!! www.afterdarkspares.com
get it while its hot! :)
noel, i reckon it'd be a good idea if you'd post up what u want from this car, both power wise and use wise i.e drags, track etc etc. then we can all start giving you some ideas to look into :P
Edited:1130pm :P
At this stage mate the best option would appear to be the bill hill one. Take your head and solid cams and hydraulic lifters to him and he converts your lifters to solid operation then installs the cams and adjusts the valve lash by trimming the valve stems. I have been told that the block may have to be welded totake care of the vct but I am looking further in to that today. He quoted me approx 400 dollars to do the job.
get it while its hot! :bunny:
noel, i reckon it'd be a good idea if you'd post up what u want from this car, both power wise and use wise i.e drags, track etc etc. then we can all start giving you some ideas to look into :banana:
where are all the -10 fittings at :(
sif get me excited then let me down Shane
ON a side note autobarm McGreggor had these fittings for similar prices when I was there a week or two ago
where are all the -10 fittings at :banana:
I take it u need -10 for ur oil cooler? theres 2 more sites i use, both american but the prices are pretty cheap (got my fuel reg from summit, really good service from them)
http://www.anplumbing.com/shop/
http://store.summitracing.com/egnsearch.asp?N=400041
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
