  • Replies 185
Posted Images
i'm laughing out loud right now....no seriously, really hard. You reckon you can rev your standardish 32 GTR to 10k safely?? I wanna see pics/vids of this....
I apologise to Noel because this does belong in another thread....so mark I challenge you to create one and tell us the mods your car has that allows you to rev to 10k??
lol.. opps meant for the other comment rev to 6500rpm + 2500rpm. or whatever someone said..? lol i never said it reved to 10,000rpm (or did i..?... NO i never said 10k..) thanks matt.. but im sure a IS200 could..?
pics of polished bits noel.. :D
Sorry, just assumed you could add. I'll attach the quotes for you from the previous page:
7500rpm and dump... IMHO
i still can rev 2500rpm higher than that... :P
Might just be me but 7,500 + 2,500 = 10,000???
I doubt it, but unlike you I never claimed it could, did I?
Latest update on build...Tore the bottom end down today. (Thanks for the help Shane) Immaculate. Its a pity to discard some of these bits but! Ordered. and on the way. Eagle rods to replace peened cryod stockers. Jun oil pump, 6 boost himount manifold. Cams. heavier valve springs, Head is going in for solid lifter conversion as soon as the cams and springs arrive.
Cam specs Tomei solids. 260 duration, 9.1 lift.
What started out as a mild street machine has turned in to a monster. Now looking at figures in the 350/400 rwkw range.
Some f**kin wheelchair. :P
no probs old fella, something to do to 'waste' the arvo away :P (i really only do it for the rumbo's ;))
i still reckon it's gonna creep on the 500rwkw figure @~24psi
shit left would be fueling, gate, & bov and thats the main bits catered for! ;)
smy thread so I can say what i like. ;);)
fair enough then lol
So "dry sump" so you can rev the tits off it is normal huh. :P
only a few ways i'll be able to get the rb30 to rev and 1 is dry sump, the other is 2+k of machine work >_<
well nengun has these 2
http://www.nengun.com/nismo/fuel-pump-skyline (276l/h)
http://www.nengun.com/hks/fuel-pump (280l/h)
i reckon one of those 2 (i like nismo over hks) would be good to feed the surge tank, than a big yank pump feeding the fuel rail :P
You dont need to go that fair Noel...
A good old Bosch 044 fitted in the tank with a raising rate reg will do the job and keep it legal...
that's dodge/cheap and you know it col lol
why play on a knife edge with a big $ engine combo for the sake of a few hundred on a fuel system, it's a no brainer in my opinion
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
