Arhhh looks like someones playing catchup :D
You have basiclly what I have now Noel, time to choose those cams so I can learn from your R&D... :D
Cause he is staying true to the cause :)
Cam selection has already been made Col. If I told you the specs I would have to kill you tho.
As for the 25 bottom end, well you are partly right. The near stock 25 I currently have impresses the sox off me given its cubic capacity. Just wanna see if i can get the right setup with the new engine to give me the punch I am looking for. If not. Onyabike 25 and welcome aboard 3.o litre.
Supporting mod selection such as cams, manifolds turbo, exhaust etc will be the key to putting the power where I want it. ( and that isnt where you have it) Time will tell if i am right or not.
  • Replies 185
Posted Images
So we have ported head, Hey noel would you please enlist and inform of the mods done to the head, ie valve springs used oversized valves? also Im interested i want to seem that damn flow sheet for the head post that biatch up. Got to know, have you yet sorted your traction and gb issues also clutch.
IE: Stronger clutch in need you going to ring Jim Berry? Or go a strong twin or triple plate clutch.
Gear Box: You going the giken internals or something stronger Getrag? That would help, You can always go the powerglide ;) if your strictly drag specing your car as that is the avenue you looking at taking?
Suspension: Please let me know what you going to choose here. CoilOvers, Whiteline kit?
Brakes: The fundamentals of stopping at the end of the track? Slotted, Upgraded calipers, Grex, Brembo etc. ?
DIFF: I dare say that A-lsd i dont think it will be the best of all to keep, well the life will be short lived im sure. 2 way? 1.5 Way?
Did you manage to get that oil cooler setup at all? or Dry Sump? :laugh:
Oh you mentioned a surge tank setup i think :S Please inform us along the way on your descision here What size, you going 1 lift 2 feed to 1.8L or 3L surge setup? or bigger :)
Cams, The fundamental of flow, i say what the hell go the 272 ex/in 10.5 lift Its the way to the sky my friend.
Cheers
:) Adam
on a side note: i thought this thread was about noel's "goodbits" oh how wrong i was.
whats different betwwen either? only difference i see would be enlarging the oil galleries in the rb30 to spin it to 8k
are you the one building a 3 litre twin cam? or have i mistaken you for someone else?
by all means enlarge the oil galleries and rev the RB30 to 8k, i bet you'll get approximately 2,000rpm shy of that.
more mods are required to get the 3L bottom end to rev to than the 2.5L bottom end. there is a great deal of difference in approach and costs.
harmonics anyone?
Cheers
:) Adam
One thing at a time Adam, Rome wasnt built in a day. But just for uou heres my wish list.
clutch will be a berry item. Gearbox will simply be stock with new bearings and cryod gear set to begin with. (we'll fight that tiger as it arises)
Brake setup will definitely be 33 gtr brembo setup. Helped andy do his and yeah. sweet brakes.
Suspension is a headache. Most coilover setups I have seen turn a nice riding car into a cart. Hate it. If sombody made an adjustable setup that started at factory settings and then upped the stiffness and rebound etc from there they would own it. Comfy near stock settings for day to day driving and some adjustability for track work would be nice.
Diff will be simply a 1.5 lsd
Oil cooler is on the way as we speak.
Sump is being sent next week for baffling, gates etc.
Cams wont be quite that radical mate. Looking for something with relatively high lift and short duration on the exhaust side and similar but with slightly more duration on the inlet.
q45 tb is on the way
q45 afm is already here.
Need a custom himmount exhaust manifold ( need probably not but want)
Splitfires this week
Pro comp power fc with hand controller. launch control and laptop port will be here in about 2 weeks time.
And the myriad of little things that arise when you undertake this type of build up. Adjusto cam gears, silicone and braided lines and hoses etc etc.
It wont happen overnight. I am a working man like most and can only do it as I can afford it.
Next step in the chain is to get the head assembled with the stiffer springs and new cams.
once the sump gets back I will fit a N1 oil pump and we will reassemble the long engine. cr is currently 8.7:1 but I may up that slightly to give a bit more squirt down low. (tuner can take care of timing to suit)
And I will have fuzzy dice for the mirror and a nodding dog for the rear parcel shelf. Thats about it Adam.
Noel man...I am running street style n1 Apexi's...and they are sweet. They are not rough at all...very nice ride i will be gettin them rebuilt if they start to fail thats how much i like em. If you want to see then i will take you for a ride.
Peace
Peace
Would love to Obi. To date i havnt seen a set i liked but i hadnt heard of these. We will definitely hook up at your convenience for a try out bloke. thanx a whole heap. ;)
What makes you think the A-LSD wont be strong enough? It is the same as a Vspec GTR it should handle anything Noel throws at it! Unless he turns really insane
Yeah they do that in a straight line...it aint broken its just how they work. Keeps you straight that way...They dont like full on burn outs but when you acutally lauch you will see it still leaves two stripes..and you wont fishtail like with other LSDs
BUT he wants to run some slicks on the sucka sometime so it'd be fairly dangerous at the strip if only 1 side is warm and the other isnt, hello concrete wall :)
Thats what you get when you use somthing designed for the pure science of the track as a caveman driving in a straight line mobile :happy:
shanef has a dry sump...but noel ...i like the way he is going response will still be awesome...maybe you might even think about putting twins on it? get some serious response from small ball bearings.
A properly sized single shouldnt have any less response than twins
Times 2. I thought about twins briefly. Too many hassles in other areas tho.
Heres a question for those in the know. Is the power fc series specific. Meaning, will a pfc for a 33 gtst work on a series 1 and 2.
Same for S1 and S2 Noel
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
