  • Replies 185
Posted Images
i'm laughing out loud right now....no seriously, really hard. You reckon you can rev your standardish 32 GTR to 10k safely?? I wanna see pics/vids of this....
I apologise to Noel because this does belong in another thread....so mark I challenge you to create one and tell us the mods your car has that allows you to rev to 10k??
lol.. opps meant for the other comment rev to 6500rpm + 2500rpm. or whatever someone said..? lol i never said it reved to 10,000rpm (or did i..?... NO i never said 10k..) thanks matt.. but im sure a IS200 could..?
pics of polished bits noel.. :D
Sorry, just assumed you could add. I'll attach the quotes for you from the previous page:
7500rpm and dump... IMHO
i still can rev 2500rpm higher than that... :P
Might just be me but 7,500 + 2,500 = 10,000???
I doubt it, but unlike you I never claimed it could, did I?
Latest update on build...Tore the bottom end down today. (Thanks for the help Shane) Immaculate. Its a pity to discard some of these bits but! Ordered. and on the way. Eagle rods to replace peened cryod stockers. Jun oil pump, 6 boost himount manifold. Cams. heavier valve springs, Head is going in for solid lifter conversion as soon as the cams and springs arrive.
Cam specs Tomei solids. 260 duration, 9.1 lift.
What started out as a mild street machine has turned in to a monster. Now looking at figures in the 350/400 rwkw range.
Some f**kin wheelchair. :P
no probs old fella, something to do to 'waste' the arvo away :P (i really only do it for the rumbo's ;))
i still reckon it's gonna creep on the 500rwkw figure @~24psi
shit left would be fueling, gate, & bov and thats the main bits catered for! ;)
smy thread so I can say what i like. ;);)
fair enough then lol
So "dry sump" so you can rev the tits off it is normal huh. :P
only a few ways i'll be able to get the rb30 to rev and 1 is dry sump, the other is 2+k of machine work >_<
well nengun has these 2
http://www.nengun.com/nismo/fuel-pump-skyline (276l/h)
http://www.nengun.com/hks/fuel-pump (280l/h)
i reckon one of those 2 (i like nismo over hks) would be good to feed the surge tank, than a big yank pump feeding the fuel rail :P
You dont need to go that fair Noel...
A good old Bosch 044 fitted in the tank with a raising rate reg will do the job and keep it legal...
that's dodge/cheap and you know it col lol
why play on a knife edge with a big $ engine combo for the sake of a few hundred on a fuel system, it's a no brainer in my opinion
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
