Hey guys,
Just wanting thoughts and peoples experiences on what you all do.
Ok, you have your normal road tyres and a set of semi's in the garage.
For a track day, do you change the tyres the day before at home and drive out to the track on the semi's?
Or change them there at the track - so taking everything out to say Oran park etc
Obviously driving with them on out to the track will reduce usage (wear and tear) but by how much etc?
Sorry for the silly questions!
:thanks:
Chris
https://www.sau.com.au/forums/topic/166829-changing-tyres-who-does-it-where/
you can do it any way you want, doesn't really matter. but man, driving 50km to the track is not going to massively wear out your tyres. i would suggest changing the wheels over at home. the day before, week before whatever. taking 8 wheels to the track is a biatch and not even possible in a 32 (may be possible in a 33).
Well if you want to do it get yourself some gear like a rattlle gun for home & maybe an electric version for the track. That & a proper jack. Otherwise it is just a time consuming pain in the arse & you will end up not bothering.
Personally i think that unless you have to commute more than about 200km's each way it is just not worth the effort. It is 600kms round trip for me to get to Wanneroo & frankly I cant be bothered changing wheels.
Remember the wear rates on the track will be massively more than those on the road. The only caveat is if you are running bulk front end -ve camber & toe out you can chew the front tyres on the roads. The other thing to worry about is tyre pressures. Get a gauge & keep track of them.
What happens if you get a flat spot, or buckle a rim on a kerb or get a puncture?
If you can fit them in the backseat+boot i'd take em out and swap em over, only takes 15mins to do.
Well, unless you are talented like me its 15 mins per tyre :huh: so I need to invest in those battery powered rattle guns!
Chubsy your to slo on the tyre changing.:huh:
You shouldnt have a problem driving them to the track.A freind of the family drives on his semi's.Thats campbelltown to wakefield and home again.im sure there are heaps of others out there that do the same.
Did you buy some r888's ftw?
I am not advocating turning up to the track without a spare. Clearly if you stuff a rim/tyre you change it. If you stuff more than one, well mostly I find people at track days are willing to help out. Failing that there is always a tilt tray....
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
