August 1991 was when there was a model revision from memory... most of the post revision (Series 2) R32's came with side intrusion bars... although, they're not exactly the best intrusion bars ever.
I might be wrong, but it sounds like someone is either trying to take you for a ride or they are simply talking shit. Did they offer to "find" you a pair of compatible doors by any chance??
I understand the rules have changed, but under the old 15yr deal all you had to do was have a set of bars fitted to the existing doors & you were good to go. Unless you're locked-in, I'd consider speaking with another shop, even if it's just for another opinion.
Good Luck
15year rule all you had to do was weld the bars in. You're getting that complied under SEVS i take it? If so then that is why you have to get the factory side intrusion bars, seems a bit stupid but hey. Their logic is that some of them came with the bars from factory so all that come through you must have them. :)
under SEVS the only R32's to have been tested were Series 2 models (why would you test an older model anyways) so they all had factory side intrusion barsd. which means if you import a Series 1 R32, then you need to "upgrade" it to Series 2 specs. What worries me is that the pathetic excuse for side intrusion bars in the S2 R32's actually passed ADRs...
that said your compliance would cost a lot more if the workshop had to test a custom made side intrusion bar for an S1 door, putting S2 doors on is the cheaper option.
Mate, that 32 probably cost shitall anyways.
A couple of doors is hardly something to fuss about. I see full doors including trim go for a couple hundred bucks for the pair.
I bet your copmliance is costing you shitall compared to what compliance used to cost. When I got my r33 imported, the price all around was 5k for RAWS copmliance. Every single place in all states were charging that.
for 5k, I could afford to buy a little spare parts division worht of doors.
Just found out I probably need to put late model doors on the 32 for complianceI just bought in Japan Land
can anyone confirm when Nissan started putting factory side intrusion bars in
ok. heres the problem. if your doing it under the 15 year rule. it wont work cos its not 15 years old.
and if its before 06/92 you cant either. under raws sheme.
unless you doctor the de-reg papers and the seatbelts and the brakehoses. also the vin number. for the "fast" screenshot that you need for an import aproval.
if its already here and being complied then yes. and god knows how they got it thru. we had to "export or destroy" our r32 test car cos it was a 6/92 not a 7/92 doh
15 yrs imports dont need the adr tested doors. cos they were not aussie deliverd. nor do they need a new cat etc etc.
its just bars/child restraints and mirror glass and a filler neck restricter. then engineers/bluslip etc etc.
I imported an R32 that didn't have side intrusion bars.
From what I understand, the problem is that the aftermarket side intrusion bars are not certified, or require an engineering certificate of some sort. However, they are identical to the series 2 intrusion bars.
What was done for me was to put the series 2 doors on for the engineers compliance, then revert back to original doors, now installed with the side bars.
It's really no different to taking out performance parts for compliance and putting them back in again later.
its 4/91 you can import 89 to June 91 or July 92 onwards
how hard is it to check the vin on fast to check the build date!
I would have thought you would know this if your a compliance shop remind me not to go through you ever
so my 91 doesnt have factory bars and I have to find some 92 onwards doors to fit up that make it clearer for you
I have a S2 R32.
Whats actually wrong with their side intrusion bars? Mine look absolutely massive, much larger and thicker than what was in my old VS commodore. :S
They occupy 1/2 of the door with only a small area at the top and bottom that is not covered; the intrusion bars look like a big arsed commerical roof support beam.
Mine was imported back in late 98 with 67,000km's on the clock. Interior really did look like a bran spanking new car. Its now cracked 238,000km's.
and if im not mistaken the sevs scheeme is no longer on isnt it. isnt that what raws is. the replacement??
dave, sevs and raws are both operating. RAWS (registered automotive workshop scheme) is what you need to go through to become a raw. a raw can then comply cars under SEVS (specialist, enthusiast vehicle scheme). so the two scheme's go hand in hand. lol, scheme is the right word...
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
