Got this last week,
Fairly stock
R33 gtst series 2 Sedan 2.5 t manual M-spec 1
Sparkling Pearl white a/m paint job
Rolling on 18 " ava wheels
119 000 k's
2 1/2 cat back exaust into twin cannon muffler
nismo 300k dash cluster
gfb hybrid bov
k & n filter insert
a/m locked diff
Edited by Traditimeour
https://www.sau.com.au/forums/topic/166862-traditimeours-new-ride/
  • 4 months later...
  • 7 months later...
been a bit slack, no fuel management yet.
Have done the standard 7psi stock boost MOD, upgraded to a R34 SMIC.
Have added a few rice mods.
Painted Dash
Clear Side Indicators
Now I'm thinking of some Black and Chrome lipped dished rims. and to pull the finger out and get the boost up
  • 1 year later...
Have installed a RB20 actuator, running 10PSI nicely.
installed a apexi pod filter, CAI and box coming shortly.
getting an oil catch to install soon. dreams of hi-flow tubro still there.
Hey, does anyone know why the climate control would be blowing really hot air, even though the temp is set at low temps?
Probably no gas in the air con.
Im told the gas is drained before cars are imported, so maybe it just needs a regas or i might have a leak somewhere.
  • 1 year later...
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
    • Sell it and buy a turbo version will make it a lot faster
