no idea to be honest... i personally would have paid up to $13-14k for it.
there's not much of a market for them really, it's flooded with $8-11K garbage. not to mention the fact that every other wannabe would rather/can get a 200rwkw for next to nothing.
the clean, straight, low km, stock examples are far and few between.
Hey just recently sold my R33 gts25 for $10.2k to the gf had it advertised for 11.5k but was getting next to no response. 1994, full 2.5 inch zorst, pod, steering wheel, 18s body kit and 92xxx genuine kms.
When selling mine found there was not much of a market for non turbo's so u should be able to pick one up quite cheap-cheap i say!
i payd $11,500 for a 97 series 2 r33 non turbo AUTO. very very clean, from a car dealer, shitty 4 month warranty but anything is better then nothing and im the first owner in australia.
the reason i got an auto was because it was alot cheaper then the manual and for a first car i really couldnt be botherd getting a manual license,il drive manual when its worth driving (turbo)
anyway all in all mine is in very good condition and is perfect for what i need it for. a daily driver, something that looks good and has a little more power then most and is very easy to drive with decent fuel consumption.
for what its worth dont get an r32 they are very old (almost 20 years old!!!) and becomming very outdated. especially if your dealing with non turbo/non performance skylines then newer is better.
sold my n/a about 4 months ago.
it was a black 1993 r33 gts4 automatic.
had a full kit.
87,000Ks
excellent condition all round, interior was closest thing to brand new.
dual airbags (driver/passenger)
sold it for $8000 with rwc and 3months rego.
personally i'd never pay more than that for an n/a skyline.
pod filter, exhaust, extractors is alot more grunt then a r33
somehow i doubt that that would give you a 26kw gain. if it did it would only make it similar in power to a 33. then do the same mods to a 33 and it will have much more power than the 32.
stock NA 33 = 104kw/ton
stock NA 32 = 94kw/ton
stock vx commodore = approx 98kw/ton
I bought my 33 from a dealership on the gold coast, MJR Motorsports, They are excellent for importing stock clean low k's cars.
Mine is a 1997 R33 GTS25 Series 2, It had 40,xxx KLMS when i bought it, ive done 4000 so far, it was 100% stock when i bought it, So far ive only put a cat back exhaust on it.
It dynoed in at 160HP/116KW At the wheels with the cat back exhaust only.
I paid $16,500 for it, A bit pricey yes, But if you see my car you would understand, Exterior, Interior and engine bay is next to showroom condition.
Edited by OBNXSH
  • 2 months later...
i have i r32 gts silver id sell very clean new respray been in an accident still getting fixed all i hit was a gutter an bent a few arms thats it, soo no chassis damage or body except the front gaurd got a scrape on the ground and is all being repaired as we speak
i need a work ute thats y im selling dont really want to but the sooner the better i suppose........
thats it in my pick
Edited by Caza
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
