Wheels are 18x9.5 work meister s1 2-piece, offset should be around +20, i had 265/40/18 michelin pilot sports all around n those were still fine and sat flushed. Also had 265/35/18 advan a048, kumho v70a and dunlop dz02g which all had no problems. The 275s that im looking at are Dunlop SP Sport series or Bridgestone Potenza series.
I'm running the same rims (Workmeister S1) in 18x10 +20 with 265 rubber and they j-u-s-t clear (had to flair the inner lips on the guards slightly). I guess the 275 on 18x9.5 would be around the same.
i have to be honest here. i can't see why you want 275 tyres in the first place? 265 is massive. and 255 is ample. especially on a 9.5inch rim a 275 will probably handle worse than a good 255 and the 275 will be heavier and more expensive.
no one can tell you for certain if it will fit or not. so many things will affect that. offset of your wheels? ride heigh of your car? castor setting? front camber? rear camber? height of bumptops? only way to find out is buy and try.
What he said! 275's would be craptacular on 9.5s.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
    • How will O2 sensor voltages help to identify it when it is sputtering?
    • What do LTFTs look like? What do MAF voltages look like? O2 sensor voltages/AFRs? Knowing O2 voltages especially when it sputters would help a lot.
