Rims are 17" and the correct offset for Skylines/Silvias - I would think around +30. Tyres are still roadworthy for a while. I have dramatically dropped the price to $700 to get rid of them.
You are most welcome to come over and try them on your car if you want to check them out.
Width?
They are 17 x 7 and looks like +33 offset (has "A0 33" on the inside which may be offset). They have 235/45/17 tyres on, but I have had 215/225s on before with no problems too.
  • 4 weeks later...
