Hi People,
I need a favour. I am getting an Error 34 on my R33 and have checked all the wiring as per the service manual. It says that there is supposed to be a 4 pin connector with only two wires running from it to each of the knock sensors.
I have had a quick look at mine and all i can see is a brown wire running from the loom which comes down parallel with the plenum to a red crimp connector and then to the sensor.
Does anyone have a photo of the connector in question and where abouts it is in the engine bay.
This has been causing me grief for many days, and I am eager to get the fault sorted out as I am running on a retarded map until it is fixed.
Thanks in advance
Aidan
https://www.sau.com.au/forums/topic/166938-knock-sensor-question/
the brown cable is actually the outer cover plastic cover for the shielding. You are on the right track. The knock sensor connector looks the same a injector connector and is black. It is diffficult to see by eye, you will need a mirror or be artful with your arms. I usually use the knock sensor retaining bolt as the locator point for my dett headphones so it is accessible just a bitch.
Edited by URAS
