  • Replies 118
mate just try this...... no ine ever said that the open throttle switch had to go on the throttle body...... they tried to tell us that too but we put it on the accelerator pedal under the dash way easy......and remember has to switch on at like 80-90% throttle not 100% like most ppl believe..... and a kind word of advice for ya..... dont ever jump on the gas while going slow or at low revs cause depending on how much gas etc u are running it will have a severe fit and a big backfire....... just my advice dude... your decision weather u use it or not as alot of ppl have varying ideas when it comes to nos.....cheers Jon
https://www.sau.com.au/forums/topic/16695-nitrous-going-on/#findComment-343055
Rev - I'm dying to see how you go - should be great.
Depending on how technical you want to go you could put a mirco switch on the gearstick so the nos is only activated when out of first gear. And if you really want to go all out, you could use a comparitor and 555 curcuit so the nos only activates over ~3500rpm, or just modify a shift light :P
Of course you'd have a normal on/off switch to stop the nos from going on at all.
That would make it a little 'easier' to drive.
Oh, and we want pics pics pics :(:)
https://www.sau.com.au/forums/topic/16695-nitrous-going-on/#findComment-343225
Yep, the 12 will be without nitrous and stock turbo. As it stands my re-tune should have me on track for a 280rwhp instead of the 230rwhp odd at 4700rpm (9's afr). The extra power I have is plenty to push me over the line for a 12.9 ,even with the razor blade 205's.
The 50 shot , and I'm afraid wider tyres, should put me into low 12's, the 100 shot into 11's.
https://www.sau.com.au/forums/topic/16695-nitrous-going-on/#findComment-343640
sorry,
That is relative to the particular dyno I went on. I'd say the stock turbo is still only 300 odd at the motor. The relative increase on that particular dyno to 280HP based on fixing afr and ping issue.
To put it another way: I'll have over 350HP at the engine.
https://www.sau.com.au/forums/topic/16695-nitrous-going-on/#findComment-344334
INASNT,
know my way around nitrous. The 100HP of nitrous is fine, just as fine as a 100HP increase with a hiflow turbo. As long as the engine internals can handle the extra power --- regardless of what provides it. The nitrous has the added benifit of correct mixture out of the box Vs new turbo that requires re-map and larger injectors etc.
As I said earlier the 50 shot is for starters, to get things sorted nicely.
The purge kit would be a good idea if I was racing and had a 250HP or so direct port. Keeps the lines 'liquified'. little power shots like mine don't need it.
Bottle warmers are good in cold weather, for the most part Perth is hot enough (except some parts of winter) to go without one.
Driving on the street with it?
No, I can't do that! Thats illegal in W.A.
https://www.sau.com.au/forums/topic/16695-nitrous-going-on/#findComment-345313
INASNT,
the system will be in the car (lines solenoids etc...) except the bottle.
The EFI kit has a preset mixture, just change the jet. The engine tuning is basic... Retard the ignition, add a little extra fuel and shift gears 500rpm odd lower than normal (the torque increase is massive).
https://www.sau.com.au/forums/topic/16695-nitrous-going-on/#findComment-345406
That's not exactly "tuning" it, is it? :D
Yes, the neatest way is to use an auxillary output as a secondary arming switch, instead of a microswitch on the throttle body/accelerator pedal... Makes it much more stealthy :)
But as rev210 said, with a wet system, the fogger gives perfect fuel for the nitrous shot, so no extra "tuning" is required with a small 50-100 shot.
https://www.sau.com.au/forums/topic/16695-nitrous-going-on/#findComment-346162
mallory I think make a nitrous rev controller. you just put in two 'pills' one lower rev range and one upper rev range and it arms the throttle pos switch based on the rpms being within the specified range.
Things like that are kind of like turbo timers, you don't need them but if your a member of AA they are helpfull.
https://www.sau.com.au/forums/topic/16695-nitrous-going-on/#findComment-346529
    • Wanted to clean the film behind the triple gauge so the lights show through better.  Progress so far….
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
