  • Replies 118
mine cost me $400 plus the $300 worth of 600HP fuel pump (cost me $200 actually).
NOS and others do kits for around $1500 for a (wet). Leave the dry kits well alone. 100HP shot on top of a stock turbo R33. The install is easy the only special tool you will need is a tap and die kit ($20 from hardware store) but, often the kit comes with the suitable tap anyway.
Nitrous is the best value mod bar none. You only need a fuel pump change. No ecu, intercooler blah blah blah...
Im pretty sure Dry is better than Wet (or maybe its the other way around)
for $1500 u can get a Pro Fogger NOS System 500hp+
why just go 4 100 when u can go 4 500 ;) (bigger is always better)
Guest INASNT
coz if he went 500 shot he would be walking to work coz his engine would blow itself to bits in a matter of seconds :)
Not when the motor will only handle 450-500hp. :)
So far my Nitrous install is pretty undetectable under bonnet. You can't see the solenoids and the braided lines are covered with good old pollution hose. As they say 'nothing to see here'.
As for the bottle: 'that subwoofer box is rather interesting.....'
I think I would go for the dummy setup my self.
I'd rather have a few bones laying around so if I were to get pulled over they would run off with the bones happily.
Then you could make it look really nice under the bonnet and be confident that all is 'legal'
Why wouldn't they?
If you use it for the drags... Get a slip handy in the glovebox presto.. A lot riskier with it hidden.
I havn't been pulled over for some time but when I do they know what they are looking for. There not that 'dumb' well the ones i've run in to arn't.
Well Rev, I have been trying to resist commenting, but I just can't. You sold out!!!! What happened to the standard turbo for 12's guy? I'm laughing and it's not from sniffing NOS. Your gunna add some nitrogen and oxygen from the dentist to make the car go faster for phissssst, that long. Do it three times and you can't do it anymore, 'till you go back to the dentist for a refill of the baby's bottle.
Shoot why don't you just take the turbo off and the intercooler and just run some more NOS? Then you could claim 11's without any turbo at all, let alone a standard one. Crikey why not sell the RB25DET and buy a RB25DE? Just add some more giggle juice, it'll be faster.
OHH! I've got a great idea, why don't you take the engine out completely and just squirt some laughing gas into the exhaust pipe and light it? Jet car man, did a 10 with no efn engine at all.
Sorry, I can hardly control myself with the laughing, I'm either gunna break a rib or pee myself. Gotta stop now.............
I don't count on dumb cops. Thats why my setup is so well hidden.
Been around cars with hidden nitrous for some time. The best strategy with a 'sleeper' is to not draw any attention to yourself in the first place (that suits the law fine because you are also unlikely to be doing illegal things on the public roads). Having a 'fake' nitrous kit is like a red flag to a bull. It may not actually work (the cops are unlikely to test this) but, you will cop a sticker for something else in the best case senario.
sydneykid,
I'm still going to get the 12 without the nitrous. But it was just too cheap to pass up. And nitrous is alot of fun. Nothing like the torque it brings instantly.C'mon for $400 would you say no?
BTW, did you know I've got a worked V8 powered volvo wagon as a family car? Complete with two baby seats and a pram. :)
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
