Hi people, reason for selling is im after something different "A CHANGE", so either i trade or sell. Let me know what u got...PM me rather than posting if thats cool! cheers!
12 MONTHS REGO!!!
Factory
*1989 NISSAN SKYLINE HR32 GTS-T M-Spec
*113,000kms
*Black
*Manual
Interior
*Rhino 3 Point immobliser Alarm system
*EL2 Apexi boost gauge
*Turbo Timer
Exterior
**In excellent condition**
**Previously belonged in the Autostyle garage.**
**White r32 gtst wheels
**Front sports lower lip
Engine
*Highflowed R33 turbo built by GCG
*Hybrid Front Mount intercooler with Custom Piping
*3-inch Full exforce exhaust system
*Fuel Cut defender
*Oil catch Can
*Turbosmart Dual stage boost controller
*Compression Test showed 145,146,145,147,145,146 PSI over the 6 cylinders (VERY GOOD SIGN!!)
Drivetrain
*Twin plate brass button clutch
*Brand New tyres
*All new front end suspension bushes
Extras
*2 spare tyres with 70% tread
*aftermarket BOV
*spare actuator off turbo
*spare dash and stereo/air con surround (in red)
*A set of original Mspec skirts and pods in this same colour as the car that are in my garage in great condition that im willing to throw in.
Car made:
*210kw@the wheels on 15psi
This car is meant for Skyline Enthusiasts who appreciate smooth efficient and safe power with reliability!!
Contact:
Or email me on: [email protected]
Located in Hurstville
Rego Expires 6/JUL/07
Had no troubles insuring with JustCar
Asking Price : $14,000 ONO MAKE AN OFFER.....I WILL CONSIDER IT
GUYS I NEED TO SELL THIS CAR....SO IF YOU WANT TO MAKE AN OFFER THEN MAKE AN OFFER....BE REALISTIC THOUGH..
Edited by RB20JT
lol......it can be delivered at ur expense....roughly between 500-700...UP TO YOU
yea im def in the market for one, not sure on how much trouble it is to get rego'd over here!!!
any other things i should know bein that i couldn't see it b4 purchase, any probs i should know or things that are needed soon???
cheers chris
not at all....i was considering replacing the spark plugs again and redoing the gaps because im not 100% on the idle...but thats me..i did a compression test and the biggest gap was 1psi between all 6 cylinders (in other words) a smooth motor.
if your interested PM me, i think getting rego is hardest in NSW. where are u? im in NSW and its a pain trying to rego a another car from interstate. Man SA is supposed to be the easiest, you guys dont get annual inspections, PLUS there is nothing wrong on this car for it to not pass inspection.
cheers,
daniel
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
