ah my gtr has been garaged for 5 months.. thats what i get for moving around the other side of the world :(
Hows life over there dude?
Someone should really go and run the motor for a few hours. Yes, my hand is up. - haha kidding :)
.....but i will do it ;)
i guess it just goes to show what it takes to keep the ol GTR on the road :) I know I could have purchased a small south american country for the dough I throw at mine. :)
The constant effort got to me, always breaking a small but significant part etc
f**king thing
Anywho - the pistons and rods are downstairs for mine.....and the turbo is at aarons......mmm, aaron, can you come to syd for a bit kthnx
https://www.sau.com.au/forums/topic/166968-my-gtr/page/3/#findComment-3100723
  • Replies 55
dude, blowing your motor is not a small part! lol hehe :D
i don't think i've ever really busted anything in the GTR. well i busted the OS tripple plate (too many trackdays/launches/skidpad/etc), i've worn out some tyres, worn out some brakes, done a few CV boots, but other than that i've spent all the dough on mods and maintenance.
https://www.sau.com.au/forums/topic/166968-my-gtr/page/3/#findComment-3101139
f**king thing
This is the part that really piss's me off i have done TWO rebuilds of my R32 and the gearbox is next but all the little things are whats really crap.
https://www.sau.com.au/forums/topic/166968-my-gtr/page/3/#findComment-3101153
yep I am so over the little things on my car,and it isn't even a GTR! SO over it I think they are both back up for sale after the July track day. As soon as you fix one stupid thing another weird noise or something starts
https://www.sau.com.au/forums/topic/166968-my-gtr/page/3/#findComment-3101520
Someone should really go and run the motor for a few hours. Yes, my hand is up. - haha kidding :D
.....but i will do it :)
f**king thing
Ill be down in a few weeks
The turbo weighs LOTS though and so does the manifold and well the gate has to go aswell.
I think ill post it. lol
ill buy the engine we built back then and put a stock one in :D
I have a complete one at the shop waiting....... :D
https://www.sau.com.au/forums/topic/166968-my-gtr/page/3/#findComment-3101556
  • 1 year later...
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
