my car is a r32 gtst type m 1992.
things i have done to fix the problem...
- clean AFM
- change fuel filter
- change O2 senser
- changed and re gapped plugs to 0.7
- cheacked coil packs.. no cracks but siliconed them up anyway...
this misfire is not the usual cough or flutter when you hit boost, this misfire happens when i am cruising at low revs, it is very random. and the whole car basically turns off for 1-4 seconds then runs again... sort of like the car stalls then role starts itself and runs again.. but smothly..??? i hope this is making sense...
could it be the ignitor box? because this controles all the coil packs? or a loose wire? i have no idea any help would be good..
thanks leigh
https://www.sau.com.au/forums/topic/167086-help-identify-my-misfire-problem/
yeah i know the o2 sensor is fine.. what is the best way to find out if the afm is gone??
the car idols fine without a hint of a miss.. as i said it is very random when it happens, like it will happen 4-5 times in a row then be fine for another 15-20 mins of driving...
with your engine idling give the wiring around the engine bay( injectors, igniter, etc etc) a good pull/wiggle and see if it plays up as it may have a bad connection somewhere and its playing up under the torque loading of the engine under acceleration
just a thought.
i just hooked up the standard wires to it... but t has been like that for about a year.. wha should i do? run a relay?
There is a link in FI Guide (sticky thread) about correctly wiring the pump :blink:
The stock loom generally is not upto the task.
So begin there.
After that, you need to mix-n-match. Swap stuff off cars you know are working and try it.
ok guys thanks for all the help i will get onto those things and if the problem persists i will post again.. it doesnt bother me to much as i am puting a rb25 with r31Nismoids old gt30 in, in the next couple of months.
thanks leigh.
  • 1 month later...
I had a similar problem 2 years ago, completely random miss but mine would happen at cruise, on boost, on idle whenever it felt like it really. It would happen maybe once every 5 minutes at worst, sometimes it wouldn't happen at all.
In the end i solved it in the same way you are planning to :)
But i tried (not in order);
afm swap
cas swap
ignitor swap
coil swap
ignition rewire
removal of emanage
plug swap
injector clean
injector swap
ecu swap
checked tps (probably should have swapped it)
rb25 engine loom and ecu swap (problem solved)
Sounds like a problem i had with my old silvia. The problem in my case was that there were 3 damaged wires going into my ecu which was shorting against one another. Maybe just have a look at the wires in that area. Its unlikely but worth a shot.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
