hi guys
at the back of the plenum where the break cylinder hoes conects to there is a small vacume output from the plenum next to the acc valve and i have no idea where it goes to i was thinking mabe its for the standard boost gauge can some please help me
thanks
you thought correctly
std boost map sensor located next to the brake booster
https://www.sau.com.au/forums/topic/167092-vacume-hose/#findComment-3092070
so can it be disconected because i cant find any hose around it to plug into it can i just block it off? where does the hoes go to exactly?
to the factory map sensor that controls the in dash boost guage, if you dont want that to work then block it off
https://www.sau.com.au/forums/topic/167092-vacume-hose/#findComment-3092212
  • 2 months later...
if i was to plug in my apexi boost gauge to this map sensor would it affect it's accuracy? seeing as i'm using the apexi gauge to replace the innacurate factory one. or is it the mechanics of the factory gauge and not the map sensor that is innacurate?
https://www.sau.com.au/forums/topic/167092-vacume-hose/#findComment-3221813
THANKYOU!
haha i thought if it was that simple i'd find some other post/s about it, but i hadn't seen a definitive answer.
did you just splice into the wires or swap the wires? i'm thinking it's probably safest to splice in case the map sensor currently also feeds the ecu etc.
https://www.sau.com.au/forums/topic/167092-vacume-hose/#findComment-3221827
You are talking about 2 different things.
1. Yes the hose is a good spot to plug the pressure sensor into (if you have an electrical gauge like an EL2 or whatever) or just run the hose to the actual gauge (if you have a mechanical gauge). I've got my pivot gauge's sensor plugged in here, was so simple to do and works well.
2. No you probably wont be able to use the stock boost gauge's sensor with your apexi gauge. The sensor will most likely have the wrong output range for your gauge. You can try it if you want, it might work but how are you going to know if what you have got now is any better than the stock one?
Rhett
https://www.sau.com.au/forums/topic/167092-vacume-hose/#findComment-3221951
thanks man - part 2 of your answer was partly addressing one of the questions i was asking tho (i.e. about using the stock boost (MAP) sensor for my gauge). Given that it is generally accepted that the factory boost gauge is not accurate, I wanted to know if it was the MAP sensor or the mechanics of the factory gauge (motor/cog whatever) itself that created the inacuracy. so you're saying it probably won't work, but mad082 is saying he is using it and that it does work.
i don't think output would be a limiting factor, just the upper limit of the MAP sensor, i've heard conflicting reports - that it can only go to 1bar/that it can only go to 2 bar?
If i was plumbing it with a tee-piece directly to the gauge or even to an aftermarket MAP sensor, i wouldn't need need to worry about the factory MAP sensor.
Edited by made_guy
https://www.sau.com.au/forums/topic/167092-vacume-hose/#findComment-3221975
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
