Does R33 Series1 Afm Suit Series2
I need to change my air flow meter on my series2 R33 GTS25t. Brand new from Nissan I've been quoted 900 bucks, so as you do I started looking for a used one but all the used ones up forsale seem to be off a series1. Would I be risking it putting one off a series1 in my series2 skyline or are they both identical since they both have an RB25DETs and all?
Any help would be greatly appreciated.
Thanks in advanced.
rb20 and rb25 series 1 have 4 wires
rb25 series 2 has 3 wires
the difference is the rb20/rb25 s1 have an extra ground for the signal ground
whereas the s2 only has 1 ground
so you can join the grounds together and it should work fine
ecu's do not differentiate between rb20/s1/s2 afms its all the same
Thanks a lot for that guys, thats great help.
So you reckon connecting my 1 ground wire to both of the s1 AFM's ground ports should do the trick?
Now only thing left is figuring out which of them is the ground :)
The two middle wires out of the four connected wires are ground, solder these two and go from there.
The ground wire for your original afm should be white with a blue stripe
Edited by BAMR33
Thanks a lot for your help everyone, managed to grab a used AFM from a wrecked series2 for just 100 bucks, put it in and car is running perfectly now. Cheers for all your help.
 Share
    • Looks like a scam. It has all the telltale signs: - The "business" doesn't have a physical address or really any kind information listed - It's using a generic online store website template - The prices are ridiculously reduced. To good to be true cheap - Everything is in stock and can be ordered in any possible combination   I've seen a few of these for other products as well. Things like sunglasses for example. I'd say stay away from it! And maybe reach out to the real theskylineshed and let them know this exists. I doubt there is much they can do about it, but still.   I don't know if they would actually take your money if you ordered something. Or whether it is just for collecting credit card details to scam otherwise. I'm not game enough to try it.
    • Hi guys has anyone ever bought from this website theskylineshed.shop?? Not theskylineshed.com as I’m aware there is 2 similar but different sites.     has anyone had any issues with theskylineshed.shop???
    • Luckily I haven’t bought one yet but I’ve had several people tell me different things and was trying to find out what’s going on with my car lol apparently type m had different lover knuckles like the gtr but someone put non type m knuckles on mine Ok on another topic does anyone have a spindle for sale mine is screwed bad lmao
    • The vendor you bought from is a dickhead who can't tell the difference between AWD and RWD bearings. Their eBay listing is one of the first hits too, and is wrong. Any other hit shows the ones that are on your car. A search for GTR rear wheel bearings, unsurprisingly, finds the one you have from Shift. f**king muppets.
    • Got the flat door cards "good enough" for now. After cutting out the arm rest I removed all the stock trim material. Then filled the gap with a bit of Masonite and wrapped it in some adhesive foam to hide the  transitions as much as possible. Then I applied some black vinyl material to the panel with some spray on contact adhesive smoothing the edges as best as I could. Here is how it sits in the car with the door handle and cut down window switch mounted
